Hello
I've got a problem with the ACAD and a Drawingboard VI. I can not digitize with the board. It only works as mouse and no 1:1 digitizing is possible. I found, that the wintab 7.46 driver should work or is there something newer out? I'm running Windows 7 with ACad LT 2009 and the digitizer via USB. Vtablet is not working. Not possible to install ( Error 8).
Does somebody had this problem and how had you solved it?
Pretty sure those drivers won't work with Win7.
