Hi,
I'm trying to find a lisp that gets the value of an attribute "COTA" tag of 2 blocks. And the distance between these blocks.
Then calculate the slope.
I have a similar code. But don't get attribute value.
(defun c:lp (/ ptoy dist altu perc)
(setq ptox (getpoint "\nClick first point: "))
(setq ptoy (getpoint "\nClick second point: "))
(setq dist (rtos (distance ptox ptoy) 2 2))
(setq altu (- (cadr ptoy) (cadr ptox)))
(setq perc (rtos (* (/ altu (atof dist)) 100) 2 2))
(princ (strcat "Distance = " dist " ; Perc = " perc "%"))
);defun
Please, see the File Attached.
It explain better my task.
Regards
e.g.dwg
(defun c:lp2 (/ _sel val b1 b2 f pt e_ diff distB)
(defun _addComma (str sp / a b m i lst)
   (if (numberp (read str))
       (setq a   (vl-filename-base str)
             b   (substr str (1+ (strlen a)))
             m   (vl-string->list a)
             i   (length m)
             lst nil
       (while (>= i 3)
         (setq lst (append (list sp
                                 (nth (- i 3) m)
                                 (nth (- i 2) m)
                                 (nth (1- i) m)
                           lst
               i   (- i 3)
         lst
       (strcat (substr str 1 i)
               (vl-list->string
                 (if (zerop i)
                   (cdr lst)
                   lst
;;;    mod
               (if b (vl-string-subst "," "." b) "")
;;    mod
(Defun _sel (msg / sel)
(princ (Strcat "\n<<Select " msg " Data>>"))
(While (null sel)
 (setq sel (ssget "_:S" '((0 . "INSERT")(2 . "SIMB_BOLINHA")))))
 (ssname sel 0))
(if
 (And (setq val nil
            b1  (_sel "First")
            b2  (_sel "Second")
      (foreach e (list b1 b2)
        (setq f  nil
              pt (cdr (Assoc 10 (entget e)))
        (if (and
              (while
                (and
                  (null f)
                  (eq (cdr (assoc 0 (setq e_ (entget (setq e (entnext e))))))
                      "ATTRIB"
                 (if (eq "COTA" (strcase (cdr (assoc 2 e_))))
                   (Setq f (cdr (Assoc 1 e_)))
              [b](progn
              (While (vl-string-position 46 f)
                    	(setq f (vl-string-subst  "" "." f)))
              (setq f (distof (vl-string-subst "." "," f)))
              (numberp f))
            )[/b]
          (setq val (cons (list f pt) val)
      (vl-every '(lambda ( x ) x )(apply 'append val))
      (= (length val) 2)
  (alert (Strcat "\nSlope: " (rtos (* (/ (setq diff (abs (- (Caar val) (caadr val))))
                             (setq distB (distance (cadar val) (cadadr val)))
                          100.00
                       2
                       2
                 "%" " \nDifference of Elevation: "[b] (_addComma (rtos diff 2 2) 46)[/b]
                     " \nDistance between BLocks: "[b] (_addComma (rtos distB 2 2) 46)[/b]
  )(princ "\n<<<Missing Information, Check Attribute Value>>>:")
Not use how accurate the result will be [As per your Formula]
Edited by pBe
I'm very impressed with the result.
It's just like I wanted to.
Many Thanks for the quickly reply and wonderful code.
:notworthy::notworthy::notworthy:
Best Regards
Best Regards
You are welcome, Glad it works for you.
Cheers
Hi,
I'm trying to add two more information inside the code, beside slope (%).
- unevenness (890,00 - 891,30) = 1.30
- distance (distance between two blocks)
In my drawing has about three kind of blocks, but the attribute is the same "COTA", and the lisp works just for SIMB_BOLINHA block.
Is it possible to add other names in the code, SIMB_PONTO, SIMB_CRUZETA?
Any help will be really wellcome, guys.
Thank in advance.
:oops:
Hi,
What is that? the difference of elevation? on what format?
(setq sel (ssget "_:S" '((0 . "INSERT")(2 . [b][color="blue"]"SIMB_BOLINHA,SIMB_PONTO,SIMB_CRUZETA"[/color][/b]))))
(setq sel (ssget "_:S" '((0 . "INSERT")(2 . "SIMB_BOLINHA[color="red"],[/color]SIMB_PONTO[color="red"],[/color]SIMB_CRUZETA"))))
Oh! I did this, but I forgot the comma. Thank you!
Yes pBe. It's the difference of elevation.
The format is decimal (In Brazil decimal mark is comma.)
Regards
  • 2 weeks later...
Hi, pBe
I don't want to inconvenience you, I'd like to ask you just one more thing.
I need incorporate two more information in the code, beside slope (%).
-difference of elevation
-distance between blocks.
I would be very grateful if you could help me, I really need these informations in the code.
Thank in advance
Hi, pBe
I already did the modification at post # 6 a week ago Madruga_SP :)---> [Last edited by pBe; 27th May 2013 at 09:57 am.]
Hi pBe
I've noticed that you updated the code.
Now, I know because didn't work.
The value of attribute when is millesimal unit is separeted by period "."
e.g 1.200,00
Sorry bother you, could you help me for the last time?
I promess you.
:oops:
I promess you.
:oops:
Code updated
I wish you wouldn't :lol:
I promise you.
Oh Whoa...In fact english is really bad.
Code updated
I'm sure I won't my friend, because your code is just fantastic!
Worked like a charm!
I'm really satisfied with the goal, it was better than I thought.
Many thanks for the great help.
God Bless you!
:D
You are welcome. Happy to help :)
