hosyn Posted May 21, 2013 Share Posted May 21, 2013 Are there any body for giving Useful lisp for electrical engineers??? Quote Link to comment Share on other sites More sharing options...
Murph_map Posted May 22, 2013 Share Posted May 22, 2013 Are there any body for giving Useful lisp for electrical engineers??? Electrical Engineer is a vast field from doing ciruits in mirco chips to electrical power line distrubution lines that cover areas as large as mulitple states. Can you narrow it down a bit? My MOL.lsp which is for Miles Of Line that tells me how many miles of power lines and on what circuit they belong too and substation name may not be worth the internet space to post for you. Quote Link to comment Share on other sites More sharing options...
pBe Posted May 22, 2013 Share Posted May 22, 2013 Are there any body for giving Useful lisp for electrical engineers??? Do you have a specific routine in mind? "Useful" to others might not be the same for all Electrical Engineers. Think "What if there's a program that can......." 1. 2. ... Quote Link to comment Share on other sites More sharing options...
tzframpton Posted May 22, 2013 Share Posted May 22, 2013 Are there any body for giving Useful lisp for electrical engineers???If you're an electrical engineer for the AEC industry doing medium voltage design, you could look into AutoCAD MEP. If you wanted to jump ship from AutoCAD you could look into Revit MEP. These two software applications are specifically designed for engineers and do a lot of calculation for you as long as your electrical equipment is set up properly in the CAD software. Quote Link to comment Share on other sites More sharing options...
