dlions78 Posted November 18, 2008 Posted November 18, 2008 Hello, please help if you are able. At my job i am required to dimension DXF files of manufactured parts to get the dimensions off of the files,print them and send them over to a fab shop. I use Autocad LT 2006 Is their a way too quick dimension DXF files "not have to manually drag each DIM?" too speed this process up? Many thanks, Quote
hazardman Posted November 18, 2008 Posted November 18, 2008 i can only think of QDIM (or quick dimension from the dimension toolbar)...i trust this is available in LT...but in the end you may be better off doing it manually depending what the content is as qdim works nicely on architectural but i don't know about mech stuff... Quote
dlions78 Posted November 18, 2008 Author Posted November 18, 2008 i can only think of QDIM (or quick dimension from the dimension toolbar)...i trust this is available in LT...but in the end you may be better off doing it manually depending what the content is as qdim works nicely on architectural but i don't know about mech stuff... Could you explain the commands and how this would typicly work? as before stated I have almost no experience with this program "just looking for something to make my life a little easier Thanks Quote
hazardman Posted November 19, 2008 Posted November 19, 2008 start the command, select all your objects then move your cursor up/down or left/right to get an entire string of dimensions...try it out and see what happens!.. Quote
