spinecad Posted May 23, 2013 Posted May 23, 2013 Undo can be done so many in the AutoCAD. Why redo can only be done once? How to set it like the undo which can be done so many? Thank you Quote
Cad64 Posted May 24, 2013 Posted May 24, 2013 Why redo can only be done once? How to set it like the undo which can be done so many? Try the MREDO command: http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%202010%20User%20Documentation/index.html?url=WS1a9193826455f5ffa23ce210c4a30acaf-49d0.htm,topicNumber=d0e273896 Quote
