yrnomad Posted November 18, 2008 Posted November 18, 2008 I'm having a problem with a drawings viewports that is annoying, but I've not found a way around it. I have a rectangular viewport showing a floor plan that takes up most of the sheet. In one area there is enough of a gap that my engineer wants an enlarged plan shoehorned in. So I put another small rectangular viewport with a detail title, basically on top of the existing viewport in that "hole". My problem lies in when I want to switch to model space in the smaller viewport, I double click inside its boundaries but that puts me in model space on the big viewport. I end up temporarily moving the little on over to clear space, as a work around. I know I can redo the viewport as a polygonal, but I'd like to aviod it if possible. Is there a way to toggle which viewport you are in? Like using the spacebar to cycle through the commands once you've gripped something. Thanks Quote
