Hi there,
I have seen a lot of autonumbering of blocks lisp examples in this forum which is a bit complicated for me.
But i just need a simple lisp that will automatically place the number in the center of the rect. after I have selected the rect. I want .
for example if i select 10 rectangle . i need the rect to be numbered 1 to 10 in sequence.
By the way can this be also applied to a hexagon?
Can anyone help?
Thanks
kenbe
Hi ReMark,,
I have seen the post by Lee Mac.
But that is not what I wanted..
There is no option for me to select the rectangles(not block) that is already on the drawing.
for me to label.
Thanks,
Regards
kenbe
Have you seen this (Incremental Numbering Suite) by Lee Mac?
http://www.lee-mac.com/numinc.html
Edited by KENBE
correction "not block"
Try this code may be it will helps
(defun C:INR (/ *error* cpt dxf elist en ent emake_txt inc info midpt pfx pts
sfx sset start tht)
;; increment numbering of rectangles
(defun *error*  (msg)
   (command "_undo"
"_end")
         (if (and msg
(not (wcmatch (strcase msg)
"*BREAK*,*CANCEL*,*QUIT*,")))
     (princ (strcat
"\nError: " msg)))
 ;;helpers:
(defun dxf (key
alist)
 (cdr (assoc key alist))
 (defun
midpt (p1 p2)
   (mapcar '(lambda(x y)(* (+ x y) 0.5))p1
p2)
 (defun emake_txt  (pt txt hgt)
;;  middle center  ;;
 (entmake (list '(0 .
"TEXT")
  '(100 . "AcDbEntity")
  '(67 .
0)
  '(8 . "0")
  '(100 .
"AcDbText")
  (cons 10(list (- (car pt) (* hgt (strlen txt)
0.47))(- (cadr pt)(/ hgt 2.))(caddr pt)))
  (cons 40
hgt)
  (cons 1 txt)
  '(50 . 0)
  '(41
. 1)
  '(51 . 0)
  '(7 . "Standard"); change on your
text style here
  '(71 . 0)
  '(72 .
1)
  (cons 11 pt)
  '(100 .
"AcDbText")
  '(73 . 2)))
;;   main part   ;;
 (if
(and
(setq pfx   (getstring "\n Prefix:
      sfx   (getstring
"\n Suffix: ")
      start (getint
"\n Starting number: ")
      step
(getint "\n Increment step: ")
      tht
(getreal "\n Text heigh: ")))
     (command "_undo" "_be")
     (prompt "\n Select rectangles in the
right order:")
     (while
(setq sset
(ssget "_+.:S:L"
    (list (cons 0
"lwpolyline")
   (cons 90
4)
   (cons 70 1))))
 (setq en (ssname sset
0))
 (setq pts (vl-remove-if 'not (mapcar '(lambda(x)(if (= 10 (car
x))(cdr x)))(entget en)))
  cpt (trans (midpt (car pts)(caddr
pts)) 1 0))
  (emake_txt  cpt (strcat pfx (itoa start) sfx)
tht)
 (setq start (+ start step))
(*error* nil)
) ;_ end of defun
(prompt
"\n\t---\tType INR to execute  \t---")
(prin1)
Hi Fixo,
I get this error (Error: bad DXF group: nil) when running the program.
Did I missed out something.
Also I want to be able to do a fence selection on the rectangles not 1 by 1.
Thanks
Regards
kenbe
sfx sset start tht)
   (command "_undo"
"_end")
         (if (and msg
     (princ (strcat
"\nError: " msg)))
 ;;helpers:
(defun dxf (key
alist)
 (defun
midpt (p1 p2)
p2)
;;  middle center  ;;
"TEXT")
  '(67 .
0)
  '(8 . "0")
  '(100 .
"AcDbText")
  (cons 40
hgt)
  (cons 1 txt)
  '(50 . 0)
  '(41
. 1)
  '(51 . 0)
text style here
  '(71 . 0)
  '(72 .
1)
  (cons 11 pt)
  '(100 .
"AcDbText")
  '(73 . 2)))
;;   main part   ;;
 (if
(and
      sfx   (getstring
"\n Suffix: ")
      start (getint
      step
      tht
right order:")
     (while
(setq sset
(ssget "_+.:S:L"
    (list (cons 0
"lwpolyline")
   (cons 90
4)
   (cons 70 1))))
0))
pts)) 1 0))
tht)
(*error* nil)
) ;_ end of defun
(prompt
(prin1)
Then go through the code and find a line where
program is fails, otherwise i need drawing to see
the problem, nothing else
this line should read like this
   '(7 . "Standard")[b]; change on your  text style here[/b]
I believe when you copy and paste the code . the line inadvertently end up like this
text style here
Anyhoo. here's a short code [demo code] UPDATED
(defun c:NRI ( /  *IntGet1 sn ss i e sum verts ptList p )
;;	pBe 25May2013	;;;
[color="blue"](defun *IntGet1 (fn msg def)
(setq type_ (vl-symbol-name (type def)))
 	(initget 6)
 	(setq val ((eval fn) (strcat msg " <" (vl-some '(lambda (x)
                (if (eq (Car x) type_)(eval (cadr x))))
                (list '("REAL" (rtos def 2 2))' ("INT" (itoa def)) '("STR" def))) ">: ")))
 (if (or (null val)
                (eq "" val))
                 def val))
(foreach Var '(("TxtHt" 1.0) ("sn" 1) ("pref" "X"))
     (if (setq dflt (eval (read (car var))))
         	  dflt (set (read (car var)) (cadr var))
(setq TxtHt   (*intget1 'getreal "\nEnter text height" TxtHt)
     sn      (*intget1 'getint "\nEnter Start Number" sn)[/color]
     pref    (strcase (*intget1 'getstring "\nEnter Start Number" pref)))
(if (setq i -1 ss (ssget '((0 . "LWPOLYLINE"))))
(repeat (sslength ss)
           (setq e     (ssname ss (setq i (1+ i)))
                 sum   '(0 0)
                 verts (cdr (assoc 90 (entget e))))
           (setq ptList
                      (mapcar 'cdr
                              (vl-remove-if-not
                                    '(lambda (x) (= (car x) 10))
                                    (entget e))))
           (foreach x ptList (setq sum (mapcar '+ x sum)))
    (setq p (mapcar '/ sum (list verts  verts)))
	(entmakex
	  (list
	    (cons 0 "TEXT")
	    (cons 10 p)
	    (cons 11 p)
	    (cons 40 TxtHt)
	    '(50 . 0.0)
	    '(72 . 4)
	    '(73 . 3)
	    (cons 1[color="blue"][b] (Strcat pref " " (itoa sn))[/b][/color]
 		(setq sn (1+ sn))
HTH
Edited by pBe
Sequence and prefix
Thanks Patrick, your demo code is much shorter than mine,
but without of seeing his sample drawing, anything is just a guess,
probably may be duplicate verices, or rectangles weren't closed
or some other things in there, who knows?
Cheers :)
..... but without of seeing his sample drawing, anything is just a guess, probably may be duplicate verices, or rectangles weren't closed or some other things in there, who knows?
You are right about that :). Lately that's all we ever do based on the recent requests/request-ers :lol:
Hi Fixo,
My sincere apologies to you. Patrick was right , I pasted the program with word warp on in Notepad and did not notice the error.
There is no error now.
But I will still need to select the rectangles one by one and I have about 80 to 100 rectangles to select in the drawing.
Hope its not too much to ask if you can modify it so that I can do a fence selection.
Thanks
Regards
Kenbe
Hi Patrick,
Thanks for the code!! That is what I basically need.
Is it possible to reverse the numbering sequence--my first selected rectangle became the last to be numbered.
Also where can I modified the program to always add a prefix "X" to the numer.
Thanks
Regards
Kenbe
text style here
(defun c:demo ( / TxtHt sn ss i e sum verts ptList p )
(initget 7)
(if (and
     (setq TxtHt (getreal "\nEnter Text Height: "))
     (setq sn (initget 7)
           sn (getint "\nEnter Start Number: ")
     (setq ss (ssget '((0 . "LWPOLYLINE"))))
           (setq e     (ssname ss (setq i (1- i)))
                 sum   '(0 0)
           (setq ptList
                      (mapcar 'cdr
                              (vl-remove-if-not
                                    (entget e))))
	(entmakex
	  (list
	    (cons 0 "TEXT")
	    (cons 10 p)
	    (cons 11 p)
	    (cons 40 TxtHt)
	    '(50 . 0.0)
	    '(72 . 4)
	    '(73 . 3)
	    (cons 1 (itoa sn))
 		(setq sn (1+ sn))
HTH
Hi Patrick,
Thanks
Regards
Kenbe
X and space then number? "X 1" or "X1"? or are you wanting to be prompted for string prefix?
CODE updated: Sequence and prefix "X"
Edited by pBe
Hi Patrick,
Thanks for everything. The code that you updated is what I have in mind!!!
Have a good Day..
Regards
kenbe
