Bill Tillman Posted May 24, 2013 Posted May 24, 2013 I think all of us know what a pain it can be to run a lisp which either crashes or someone presses the Esc key too soon. Some real problems can result from this especially if you've reset environment variables. I found this code somewhere back in history and it's served me well. But I was wondering if others had routines which may improve on this method. I have this code in a file of it's own and it get's loaded as needed. The best part of this is that if the program crashes or someone hits Esc, the error routines kick in and all variables which were set for the program to run are reset to their original values. Which makes for happy users and less complaints. (defun c:main_program () ; start the programs off like this ; INITIALIZE ------------------------------------------------------------------------------ (load "/my_path/ErrorTrap.lsp") (error) (initerr) (setvar "cmdecho" 0) (setvar "osmode" 0) (setvar "pickbox" 0) (command "._CLAYER" "0") (setvar 'CECOLOR "ByLayer") (setvar 'CELTYPE "ByLayer") . . . ;-------------------------------------------------------------------------------------; ; Program Name: ErrorTrap.lsp LATEST REVISIONS 2012-10-12 ; ; Date Created: 10-12-2012 ; ; Company: ; ; ; Error Trapping Routines ; ; ; ;-------------------------------------------------------------------------------------; ; Revision History ; ; Rev By Date Description ; ;-------------------------------------------------------------------------------------; ; 1 BT 10-12-2012 Initial version ; ;-------------------------------------------------------------------------------------; ;-------------------------------------------------------------------------------------; ; ERROR TRAPPING ROUTINES 10-12-2012 ; ;-------------------------------------------------------------------------------------; (defun error() (prompt "\nGlobal Error Trap Loaded") (princ) ) ;*====================================================================; (defun initerr () (setq oldlayer (getvar "clayer")) (setq oldsnap (getvar "osmode")) (setq oldpick (getvar "pickbox")) (setq oldblip (getvar "blipmode")) (setq temperr *error*) (setq *error* trap) (princ) ) ;*====================================================================; (defun trap (errmsg) (command nil nil nil) (if (not (member errmsg '("console break" "Function Cancelled"))) (princ (strcat "\nError: " errmsg)) ) (setvar "clayer" oldlayer) (setvar "blipmode" oldblip) (setvar "menuecho" 0) (setvar "highlight" 1) (setvar "osmode" oldsnap) (setvar "pickbox" oldpick) (princ "\nError Resetting Enviroment ") (terpri) (setq *error* temperr) (princ) ) ;*====================================================================; (defun reset () (setq *error* temperr) (setvar "clayer" oldlayer) (setvar "blipmode" oldblip) (setvar "menuecho" 0) (setvar "highlight" 1) (setvar "osmode" oldsnap) (setvar "pickbox" oldpick) (setvar "CELTYPE" "ByLayer") (command "CELTSCALE" 1.00) (princ) ) ;*====================================================================; Quote
BlackBox Posted May 24, 2013 Posted May 24, 2013 I used to do something similar when I first started to incorporate error handling... I found though, that different functions needed different 'restore' functionality, and by defining my own error function, I either needed to change the name of each-and-every-one so as to not rick overwriting another, or simply embed the error handler as a local variable, so the default error handler is never accidentally overwritten, and is restored as soon as my local error handler goes out of scope. The latter (localized error handler) has proved to simpler, easier to maintain, and all around better for my work. HTH Quote
fixo Posted May 24, 2013 Posted May 24, 2013 This is may be interesting to see too: http://adndevblog.typepad.com/autocad/2012/05/undo-inside-a-lisp-error-handler.html Quote
pBe Posted May 25, 2013 Posted May 25, 2013 This is may be interesting to see too:http://adndevblog.typepad.com/autocad/2012/05/undo-inside-a-lisp-error-handler.html Interesting indeed Oleg Quote
