archaeoman Posted May 27, 2013 Posted May 27, 2013 Greetings everyone, I am a new member of this forum, however I have been reading the posts for some time. I am an archaeologist working with survey equipment and Map3D for a few years but now I have the following problem. When I import the shapefiles created in my leica/topcon equipmrnt into Map3D (mapimport) there is the possibility to select which attributes are going to be imported with an import profile file (.ipf). How do I create the above and save it so that I do not have to go through the same process again? Thank you for your help and I hope you can help me. Quote
Murph_map Posted May 27, 2013 Posted May 27, 2013 The answer was given in the Autodesk forums for anyone who may have the same question. Quote
