Hi,
I have a string that I obtain from excel (0.0 1.2 1.2 1.2),
I can convert that to a list so that it is ("0.0" "1.2" "1.2" "1.2")
how can I convert it that each string in the list is actually a real number?
I thought I could use the "foreach" function combined with atof but I cannot seem to get it to work.
any ideas?
thanks
If you wish to use foreach function , here is an example .
(foreach x '("0.0" "1.2" "1.2" "1.2")
 (setq l (cons (read x) l))
(reverse l)
Please don't miss that what you have listed there is a list, not a string. A string will look like:
"0.0 1.2 1.2 1.2"
And you will need to split it by spaces and after use ATOF or DISTOF to convert in real numbers.
Hi,
That is giving me an error. see below code.
(setq dist_list (getcell "I10"))
 (setq dist_list (sinc:String->List dist_list " "))
(foreach x dist_list
 (setq dist_list1 (cons (read x) dist_list))
(reverse dist_list1)
(print dist_list1)
(1.2 "0.0" "1.2" "1.2" "1.2") Fehlerhafter Argumenttyp: numberp: "0.0"
Maybe , check it out
 (setq dist_list1 (cons (read x) dist_list[color=red]1[/color]))
I have used this from another forum by pbejse!
(mapcar 'Read dist_list)
The majority of talent users have accounts in all around forums , so if you post your question all around the forums , you'd get and see the same users with the same answer mostly .
(print dist_list1)
You can skip a few steps:
(read (strcat "(" (getcell "I10") ")"))
..(setq dist_list (getcell "I10"))
(setq dist_list (sinc:String->List dist_list " "))......
The OP and i never got that far on the other forum :D,
I guess it depends on the getcell or sinc:String->List subfunction feargt is using. as you can see from the "error"
Somewhere along the way, one of the element ended up as a real number.
Then yes, Lee's suggestion to skip conversion of cell value to string and then back makes sense.
the above was actually originally posted by Lee-MAc
Thanks for all the replies on this. I will try this one out later today.
