[ATTACH]42148[/ATTACH]Hi All,
anyone can help me. I have VBA coding, it's working fine in AutoCAD 2008, but it's not working in 2011.
Edited by ramanusu
  • 2 weeks later...
If you still have the VBA code, you should be able to make it work.
1. You need to have "AutoCAD 2011 VBA module" installed.
2. Edit your VBA project, change all those "missing" references to current version.
THanks for reply, I did this 2 steps. I can't get focus to autocad window for pick the points.
Yes... you are right... i have same problem in my VBA code. I ran that tool in autocad, still i have same problem.
Thanks
