spiker7221 Posted May 30, 2013 Posted May 30, 2013 Good afternoon, I'm trying to create simple toolbar icons to rotate my view while building elevations and roof layouts. The existing buttons work fine, but zoom extents when I change UCS rotations. For some reason, my code is capturing the viewctr wrong. I just want to carry my zoom factor and view center to the next rotated UCS plan view. Any help would be much appreciated. Thanks for all your help, Mike in Dallas (defun C:ELS (/ vctr vsze) (setq vctr (getvar "viewctr")) (setq vsze (getvar "viewsize")) (command "ucs" "W") (command "plan" "") (command "zoom" "_c" vctr vsze) ) ; ; ; (defun C:ELN (/ vctr vsze) (setq vctr (getvar "viewctr")) (setq vsze (getvar "viewsize")) (command "ucs" "z" "180") (command "plan" "") (command "zoom" "_c" vctr vsze) ) ; ; (defun C:ELE (/ vctr vsze) (setq vctr (getvar "viewctr")) (setq vsze (getvar "viewsize")) (command "ucs" "z" "90") (command "plan" "") (command "zoom" "_c" vctr vsze) ) ; ; (defun C:ELW (/ vctr vsze) (setq vctr (getvar "viewctr")) (setq vsze (getvar "viewsize")) (command "ucs" "z" "270") (command "plan" "") (command "zoom" "_c" vctr vsze) ) Quote
BlackBox Posted May 30, 2013 Posted May 30, 2013 You could always just TWIST, and UNTWIST your view (no more zoom): (vl-load-com) ;;;--------------------------------------------------------------------; ;;; Twist dview function: (defun c:TW () (c:TWIST)) (defun c:TWIST (/ *error* RTD oldCmdecho oldOsmode pt1 pt2 acDoc) (prompt "\rTWIST") (defun *error* (msg) (and oldCmdecho (setvar 'cmdecho oldCmdecho)) (and oldOsmode (setvar 'osmode oldOsmode)) (if acDoc (vla-endundomark acDoc) ) (cond ((not msg)) ; Normal exit ((member msg '("Function cancelled" "quit / exit abort"))) ; <esc> or (quit) ((princ (strcat "\n** Error: " msg " ** "))) ; Fatal error, display it ) (princ) ) (defun RTD (ang) (/ (* ang 180.0) pi)) (if (and (setq oldCmdecho (getvar 'cmdecho)) (setvar 'cmdecho 0) (setq oldOsmode (getvar 'osmode)) (setvar 'osmode 512) (setq pt1 (getpoint "\nSpecify start point (left): ")) (not (initget 32)) (setq pt2 (getpoint "\nSpecify end point (right): " pt1)) ) (progn (vla-startundomark (setq acDoc (vla-get-activedocument (vlax-get-acad-object))) ) (command "._dview" "l" "" "PO" "@0,0,0" "@0,0,1" "") (command "._dview" "l" "" "tw" (- 360 (RTD (setq ang (angle pt1 pt2)))) "" ) (setvar 'snapang ang) ) ) (*error* nil) ) ;;;--------------------------------------------------------------------; ;;; Untwist dview function: (defun c:UTW () (c:UNTWIST)) (defun c:UNTWIST (/ *error* oldCmdecho) (prompt "\rUNTWIST") (defun *error* (msg) (and oldCmdecho (setvar 'cmdecho oldCmdecho)) (and oldNomutt (setvar 'nomutt oldNomutt)) (if acDoc (vla-endundomark acDoc)) (cond ((not msg)) ; Normal exit ((member msg '("Function cancelled" "quit / exit abort"))) ; <esc> or (quit) ((princ (strcat "\n** Error: " msg " ** "))) ; Fatal error, display it ) (princ) ) (setq oldCmdecho (getvar 'cmdecho)) (setvar 'cmdecho 0) (command "._dview" "l" "" "tw" 0 "") (setvar 'snapang 0) (command "._UCS" "W") (*error* nil) ) Quote
