ktpfvr Posted November 19, 2008 Posted November 19, 2008 I am trying to plot/print a 3D drawing. What keeps happening is CAD keeps freezing when I hit ok on the print dialog box to send to the printer. It shows the print progress screen but completely freezes everytime. In that same drawing I can plot/print some 2D drawings. I have tried purging, audit, and even overkill. I have tried xref'ing the 3D into another drawing, I have taken just the 3D to a new drawing, and I have even tried making the 3D a block. Nothing seems to work, any ideas? Thank you Quote
Strix Posted November 19, 2008 Posted November 19, 2008 what's the printer and how is buffering taking place? Quote
ktpfvr Posted November 19, 2008 Author Posted November 19, 2008 what's the printer and how is buffering taking place? It is a regular Canon printer/Copier. I print the 2D drawings to the same printer so I don't think the printer is the issue. I believe the issue is when CAD goes to Hide the lines for 3D, it just freezes. Quote
Strix Posted November 19, 2008 Posted November 19, 2008 is the spec of your machine compatible with the version of ACAD you're running then? Quote
ktpfvr Posted November 19, 2008 Author Posted November 19, 2008 Yes it is I had two other people try and they had the same problem I had. It is the drawing. Quote
Cad64 Posted November 19, 2008 Posted November 19, 2008 It sounds like maybe it's a memory problem? How large and complex is the model? Quote
ktpfvr Posted November 19, 2008 Author Posted November 19, 2008 It sounds like maybe it's a memory problem? How large and complex is the model? The file is 6,348Kb Quote
skipsophrenic Posted November 19, 2008 Posted November 19, 2008 Have you tried to plot it after using the HIDE commande before trying to plot the model, this in effect hides the lines before you send the dwg to plot Quote
dumfatnhappy Posted November 19, 2008 Posted November 19, 2008 I'm betting you need to plot it to a file (PDF,PLT,DWF, etc) and then send that to the printer.... not enough memory to spool either that or plot as you are and leave it alone over night and see what happens by morning Quote
skipsophrenic Posted November 19, 2008 Posted November 19, 2008 plot as you are and leave it alone over night and see what happens by morning Didn't think of that an i've had to do it a couple of times, this might work. Quote
