Ok so I am using 2013 now every so often ( around 2 times a month ) AutoCAD will dump my custom profile.
I tried saving it to my local drive ( C drive ) and it still dumps the profile.
All the standard tool bars and custom tool bars I have are gone.
Even when I try to insert a block all my folder shortcuts are gone....
Does anyone have this same issue or a fix ????
What is the path to the custom profile?
It loads from our server under Acad-Users-jbautis
Have you tried putting this profile on your Desktop and seeing if AutoCAD still loses it?
Yes and the same issue happens....
I opened up the options menu under tools and select the profiles tab then double click the profile that I am using and it will reload but all the tool bars will be in the wrong place if not missing completely.
However the shortcuts to the folders I created will disappear completely....
:reallymad:
Frustrating.
Wow, your computer really doesn't like you does it?
And the path to your profile is clearly defined in the Support File Search Path?
Tell me about it !!!!!!!
Yeah all the paths are correct.
Stupid thing hates me ahhhhhhhhhhhhhh
No help from your IT department?
Have you tired making your profile "current" in Options > Profiles?
Yeah no help from IT....
Profile is current ....
Maybe I need a new machine
