willbacker45 Posted May 31, 2013 Posted May 31, 2013 Hi all, I am new to the discussion groups but have been looking up answers here a lot. I want to thank you all for taking the time to help out! I work in Rail Development and I am trying to create an assembly that will automatically generate a rail/tie shape and label Top of Rail Elevations, Track name and number, and offset distance. I have been copying/pasting a block onto each track in every cross section. This takes way too long! I have attached an image of what I want the assembly to look like in the cross section. Before now, I have been typing in all of that information, when there are 9 tracks and 77 cross sections, it becomes quite time consuming! Any tips would be very much appreciated! Thanks! Will Quote
hugha Posted June 1, 2013 Posted June 1, 2013 At first glance I'd suggest adding attributes to the block to position the text. You may already be doing this. More complete automation would involve inserting the block at a picked point and feeding those values in from a row in an external table. Many ways to skin that cat. This may help: http://www.cadtutor.net/forum/showthread.php?15732-controlling-titleblock-attributes-with-excel-sheet Quote
LibertyOne Posted June 1, 2013 Posted June 1, 2013 Are you able to extract data from other plans/dwg's to use in your sections? Quote
willbacker45 Posted June 3, 2013 Author Posted June 3, 2013 Thank you for the responses. I would like to have the assembly read from our prof/alignments and then just display the information in the cross-section. This can be done, as I have done it before. I just cant remember how I got it to work! Quote
ReMark Posted June 3, 2013 Posted June 3, 2013 Maybe you used attributes and an Excel spreadsheet? Quote
willbacker45 Posted June 3, 2013 Author Posted June 3, 2013 It is a marked point with offset and elevation labels. Quote
willbacker45 Posted June 3, 2013 Author Posted June 3, 2013 I know that I didn't reference a table. Everything is read straight off of the profile and alignments that the corridor follows. Quote
ReMark Posted June 3, 2013 Posted June 3, 2013 Then you must have used a feature unique to the program or a field. Quote
willbacker45 Posted June 3, 2013 Author Posted June 3, 2013 ReMark, thank you for your help. I think that I figure it out. I had made a custom label style with the marker being a block that I created to represent the track. Quote
