(setq tset (ssget "_C" pw1 pw2 '((0 . "text" ))))
(if (/= tset nil)
 (setq ss3(ssadd tset ss3))
I need to add the all selected texts by several windows to a single set.
Please correct my code
(setq tset (ssget '((0 . "*TEXT"))) i 0)
(while (< i (sslength tset))
(setq SS3 (ssadd (ssname tset i) SS3))
(1+ i))
Edited by lyky
(setq ss3 (ssadd))
(if (setq tset (ssget "_C" pw1 pw2 '((0 . "TEXT"))))
 (repeat (setq i (sslength tset))
   (ssadd (ssname tset (setq i (1- i))) ss3)
(if (/= tset nil)
Probably try some thing like this
(setq coll (ssadd))
(while(and (setq p1 (getpoint "\nFirst corner: "))
(setq p2 (getcorner p1  (getpoint "\nOpposite corner: "))
(setq tset (ssget "_W" p1 p2 '((0 . "text" ))))
(while (setq en (ssname tset 0))
(ssadd en coll)
(ssdel en tset)))))
(alert (strcat "Collected: " (itoa (sslength coll))))
not tested though, just from the top of my head
Edited by fixo
thanks Tharwat
(ssadd coll en)
I guess it is on the contrary :)
(ssadd en coll)
(ssadd en coll)
Thanks , fixed above
There is no need to assign the new adds to the variable ss3 every time you add more entities to it , it's enough like this .
(ssadd <entity> SS3)
You're welcome .
Thank for all. I used your codes this way.
 (setq ss3(ssadd en ss3))
Here is my take on merging multiple selection sets:
[color=GREEN];; Selection Set Union  -  Lee Mac[/color]
[color=GREEN];; Returns the union of a list of Selection Sets[/color]
([color=BLUE]defun[/color] LM:ss-union ( lst [color=BLUE]/[/color] i out )
   ([color=BLUE]setq[/color] lst ([color=BLUE]vl-sort[/color] lst '([color=BLUE]lambda[/color] ( a b ) ([color=BLUE]>[/color] ([color=BLUE]sslength[/color] a) ([color=BLUE]sslength[/color] b))))
         out ([color=BLUE]car[/color] lst)
   ([color=BLUE]foreach[/color] ss ([color=BLUE]cdr[/color] lst)
       ([color=BLUE]repeat[/color] ([color=BLUE]setq[/color] i ([color=BLUE]sslength[/color] ss))
           ([color=BLUE]ssadd[/color] ([color=BLUE]ssname[/color] ss ([color=BLUE]setq[/color] i ([color=BLUE]1-[/color] i))) out)
   out
And here is a shortcut method providing all selection sets are in the same space:
([color=BLUE]defun[/color] ss-union ( lst )
   ([color=BLUE]apply[/color] '[color=BLUE]vl-cmdf[/color] ([color=BLUE]append[/color] '([color=MAROON]"_.select"[/color]) lst '([color=MAROON]""[/color])))
   ([color=BLUE]ssget[/color] [color=MAROON]"_P"[/color])
Call with list of selection sets.
