Helo everyone,
I'm trying to create a reactor to re-align a text with a modified line.
First of all the program create a line and a text that must be put on his mid point.
Then I want the reactor to move the text and re-align it every time I change the line.
Can anyone help me ?
(vl-load-com)
(defun c:line-draw ()
(setq OSMO (getvar "osmo"))
(setvar "osmode" 0)
(setq acadDocument (vla-get-activedocument (vlax-get-acad-object)))
(setq mspace (vla-get-modelspace acadDocument))
(setq apt (getpoint "Specify First Point: "))
(setq pt (getpoint "Specify next point: " apt))
(setq myLine (vla-addline mspace (vlax-3d-point apt)(vlax-3d-point pt)))
(setq ang1 (rtod (angle apt pt)))
(if (and (> ang1 90)(
(setq ang1 (rtod angle pt apt))
(command "text" "J" "MC" (polar apt (dtor ang1) (/ (distance apt pt) 2)) 15 ang1 (rtos (distance apt pt) 2 0))
(setq myText (entlast))
;(setq textReactor (vlr-object-reactor (list myText)
;"Text Reactor" '((:vlr-modified . update-text))))
(setq lineReactor (vlr-object-reactor (list myLine)
"Line Reactor" '((:vlr-modified . print-length))))
);defun
(defun print-length (notifier-object reactor-object parameter-list)
(setq a notifier-object)
(setq b reactor-object)
(setq ang2 (rtod (angle (assoc 10 (entget a)) (assoc 11 (entget a)))))
(if (and (> ang2 90)(
(setq ang2 (angle (assoc 11 (entget a)) (assoc 10 (entget a))))
(setq ang2 (dtor ang2))
(setq myText-prop (entget myText))
(setq alg-pt (cdr (assoc 11 myText-prop)))
;(cond
; ((vlax-property-available-p notifier-object "Length")
;| (progn |;(setq comp (rtos (vla-get-length notifier-object)))
(setq myText-prop (subst (cons 1 (rtos comp 2 0)) (assoc 1 myText-prop) myText-prop))
(setq myText-prop (subst (cons 50 ang2) (assoc 50 myText-prop) myText-prop))
(entmod myText)
(setq OSMO (getvar "osmode"))
(setvar "osmode" 0)
(command "move" myText "" alg-pt (polar (assoc 10 (entget a)) ang2 (/ (vla-get-length a) 2)))
(setvar "osmode" OSMO)
;);cond
);defun
(defun rtod (ang)
(/ (* ang 180) pi)
(defun dtor (ang)
(/ (* ang pi) 180)
You have some mistakes in your code, but I think you're looking for something similar to this :
(defun c:objreac ( / myreactor )
 (setq myreactor (vlr-object-reactor (list myline) "Object Reactor : " '((:vlr-modified . print-align-text))))
 (vlr-add myreactor)
(defun print-align-text ( owner reactor lst / sp ep a d )
 (setq sp (vlax-curve-getstartpoint myline))
 (setq ep (vlax-curve-getendpoint myline))
 (setq a (angle sp ep))
 (setq d (distance sp ep))
 (vla-put-textstring mytext (rtos d 2 )
 (vla-put-alignment mytext acalignmentmiddlecenter)
 (vla-put-textalignmentpoint mytext (vlax-3d-point (mapcar '/ (mapcar '+ sp ep) (list 2.0 2.0 2.0))))
 (vla-put-rotation mytext a)
(defun c:myline ( / sp ep a d )
 (vl-load-com)
 (setq sp (getpoint "\nPick start point : "))
 (setq ep (getpoint sp "\nPick end point : "))
 (setq myline
   (vla-addline
     (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object)))
     (vlax-3d-point sp)
     (vlax-3d-point ep)
 (setq mytext
   (vla-addtext
     (rtos d 2
     (/ d 25.0)
 (alert "\nType [Command: objreac] to activate object reactor for line entity")
It works on my PC...
P.S. Please use [noparse]
 Your code here
[/noparse] tags, instead of quote tags for posting your code...
M.R.
Thank you very much marko_ribar!
Your code Works perfectly fine.
But I'm afraid I would like to get a little further with it.
Actually the code Works just for the last line created and I wanted that to happen with every line I create in my drawing.
Is it possible to do?
I'm stucked on multiple variable creation.
Thanks in advance.
Thanks in advance.
Something like this :
 (setq myreactor (vlr-object-reactor (mapcar '(lambda (x) (car x)) mylines+mytexts) "Object Reactor : " '((:vlr-modified . print-align-text))))
 (vlr-add myreactor)
 (setq sp (vlax-curve-getstartpoint owner))
 (setq ep (vlax-curve-getendpoint owner))
 (vla-put-textstring (cdr (assoc owner mylines+mytexts)) (rtos d 2 )
 (vla-put-height (cdr (assoc owner mylines+mytexts)) (/ d 25.0))
 (vla-put-alignment (cdr (assoc owner mylines+mytexts)) acalignmentmiddlecenter)
 (vla-put-textalignmentpoint (cdr (assoc owner mylines+mytexts)) (vlax-3d-point (mapcar '/ (mapcar '+ sp ep) (list 2.0 2.0 2.0))))
 (vla-put-rotation (cdr (assoc owner mylines+mytexts)) a)
(defun c:mylines ( / myline mytext str loop sp ep a d )
 (vl-load-com)
 (setq loop T)
 (while loop
   (setq myline
     (vla-addline
       (vlax-3d-point sp)
       (vlax-3d-point ep)
   (setq mytext
     (vla-addtext
       (rtos d 2
       (/ d 25.0)
   (setq mylines+mytexts (cons (cons myline mytext) mylines+mytexts))
   (if (not (eq (setq str (getstring "\nENTER to continue making lines; any key+ENTER to finish : ")) "")) (setq loop nil))
 (alert "\nType [Command: objreac] to activate object reactor for line entities")
M.R.
