tzframpton Posted June 2, 2013 Posted June 2, 2013 I have 3ds Max Design 2013 installed at home using one of our home use licenses. These licenses are usually for a 12 month period, and they expire. I just sat down and opened up the application and it's now expired but I can't find a way to update to the new license information. I have the new info from logging into my company's VPN. Worst case scenario I gotta wait until Monday to get with our Autodesk software admin, but had an open evening as well as a free day tomorrow to fiddle around and thought I'd see if someone knew so I could get some much needed personal time in. Thanks in advance! Quote
harrison-matt Posted June 2, 2013 Posted June 2, 2013 Usually the about dialog will have a models dialog for licensing. Here you can see about borrowing licenses, identifying licenses servers, etc etc. I haven't heard of Autodesk or re-sellers citing a 'home use' license. That sounds more of a company nomenclature. It does sound like you borrowed a license. Make sure you are connected to the domain so flexnet can check another for you. Best of luck. Quote
tzframpton Posted June 2, 2013 Author Posted June 2, 2013 Usually the about dialog will have a models dialog for licensing. Here you can see about borrowing licenses, identifying licenses servers, etc etc.That's the problem, I can't get past the Activate Splash screen at all. When I run through all the possible prompts there's no option to update the license - just stays stuck on the current license. I haven't heard of Autodesk or re-sellers citing a 'home use' license. That sounds more of a company nomenclature. It does sound like you borrowed a license. Make sure you are connected to the domain so flexnet can check another for you.I did not transfer/borrow a license: Home Use licensing is a common thing from Autodesk and is written in the EULA. I work for a very large company and we have home licensing options available to us with specific licensing information. Quote
welldriller Posted June 2, 2013 Posted June 2, 2013 Do not know if this will help or not but thought you might want to check it out. http://usa.autodesk.com/adsk/servlet/pc/index?siteID=123112&id=19820210 Quote
