Hello guys,
Here I am again in need of some help.
My last routine obligated me to start learning some DCL and I a problem has just turned out to me.
I have a couple of EditBoxes and I want to avoid the user to insert letters in it.
It seems to be kind of easy, but after a hundred of attempts nothing was achieved and I am here looking for some help.
How can I "lock" a EditBox to receive only numerical input?
  • Replies 29
  • Tharwat
    8
  • DaveC
    5
  • Roy_043
    5
  • pBe
    3
Hello guys,
It is. look into errtile function.
errtile example linky
Replace the validate sub to this
(defun validate ()
(if (not (numberp (read (get_tile "ValidNumber"))))
         (set_tile "error" (strcat "Only Accepts Numeric Value"))
         (mode_tile "ValidNumber" 2))
         (done_dialog)
Help is here. Now all you had to do is figure out the rest :)
HTH
Consider this just as an example .
Dcl codes ...
Test : dialog { label = "Just an example";
        : boxed_column {
        : row {
            : text
            { label = "Enter First Number  : "; alignment = left; }
            : edit_box  { key = "e1";   alignment = right; fixed_width = true ; }
        : row {
            : text { label = "Enter Second Number : " ; alignment = left; }
            : edit_box  { key = "e2";  fixed_width = true ; }
        : spacer { height = 0.25; }
    : row { alignment = centered ;
        : button    {label = " Okay ";    key = "accept";  is_default = true;  }
        : button    {label = " Cancel ";  key = "cancel";  is_default = false; }
The lisp codes ...
(defun c:Test (/ *error* id v1 v2)
(defun *error* (x) (princ "\n*Cancel*"))
 (setq id (load_dialog "Test.dcl"))
 (if (not (new_dialog "Test" id))
   (progn (alert " Error in loading the dialog (Test.dcl) ")
          (exit)
 (action_tile
   "accept"
   "(setq v1 (get_tile \"e1\")
                    v2 (get_tile \"e2\")) (done_dialog)"
 (action_tile "cancel" "(done_dialog)")
 (start_dialog)
 (unload_dialog id)
 (if (or v1 v2)
   (cond ((and (not (numberp (read v1))) (not (numberp (read v2))))
          (progn (alert "The two Inputs are not NUMBERS !!") (C:TEST))
         ((and v1 (not (numberp (read v1))))
          (progn (alert "The two Value in Edit Box-1 is not NUMBER !!")
                 (C:TEST)
         ((and v2 (not (numberp (read v2))))
          (progn (alert "The two Value in Edit Box-2 is not NUMBER !!")
                 (C:TEST)
         (t
          (princ
            (strcat "\n Your Input values are ... < " v1 " > and < " v2
Hello guys,
You can also use the callback function to get a numerical result of textbox input
and avoid to input the letters and comma, see quick example
;; digit input textbox example ;;
(defun C:DRTL (/ box_callback dcl_id text pick)
 ;; call back helper
 (defun box_callback(text act / input)
   (if (= act 2)
   (if
     (not (numberp (read (setq input (get_tile "txt")))))
     ;| ;;;could use as well: (not (vl-some 'not (mapcar '(lambda(x)(member x (vl-string->list "0123456789.")))(vl-string->list input) )))|;
    (set_tile "txt" "Put digits and dot only" )
    (mode_tile "txt" 2)
    (set_tile "txt" input )))
 (setvar "CMDECHO" 0)
 (setq dcl_id (load_dialog "DRTL.dcl"))
 (if (not (new_dialog "DRTL" dcl_id))
   (exit))
(action_tile
 "txt"
 "(box_callback $value $reason)"
 (action_tile "accept" (strcat
  "(progn "
   "(setq result (get_tile \"txt\"))"
    "(done_dialog 1))"))
 (action_tile
   "cancel"
   "(done_dialog 2)")
 (setq pick (start_dialog))
 (unload_dialog dcl_id)
 (if (= pick 1)
   (alert (strcat "You entered: " result)))
 (setvar "CMDECHO" 1)
DCL
//dcl_settings : default_dcl_settings { audit_level = 3; }// might be commented before to get it to work
DRTL : dialog {
label = "Enter numeric value:";
 :row {
 fixed_width = true;
 : boxed_column {
 label = "--- Allow input the digits an dot only ---";
 fixed_width = true;
 width=36;
 : edit_box {
 key = "txt";
 initial_focus="1";
 edit_width =36;
 spacer;
 ok_cancel;
Nice one my friend.
Here;s one for multiple edit box:
LSP:
(defun C:demo (/ dcl_id v)
     (setq dcl_id (load_dialog "demorerrortest.dcl"))
     (if (not (new_dialog "ErrorTest" dcl_id))
           (exit)
     (mode_tile "Number1" 2)
     (action_tile "accept" "(setq v (validate))")
     (action_tile "cancel" "(done_dialog 0)")
     (start_dialog)
     (print v)(princ)
(defun validate ( / vals stp)
(if (not (vl-every '(lambda (v)
    (if (numberp (setq val (read (get_tile v))))
      		(setq vals (cons val vals))
      		(setq stp v x nil)))
    		'("Number1" "Number2" "Number3")))
         (mode_tile stp 2))
   (progn (done_dialog 1)(reverse vals))
DCL
ErrorTest : dialog
{label = "Numbers only Demo";
: boxed_column {
: text { label = "Enter Numerical Values";
alignment = centered;}
: edit_box  { key = "Number1"; label=" Edit Box 1";}
: edit_box  { key = "Number2"; label=" Edit Box 2";}
: edit_box  { key = "Number3"; label=" Edit Box 3";}
spacer ;
: row { alignment = centered;
: button { key = "accept";
label = "Accept";
is_default = true;
: button { key = "cancel";
label = "cancel";
: errtile {alignment = centered;}
HTH
(defun validate ()
         (done_dialog)
HTH
Thanks pBe, Tharwat and Fixo for the quick replies.
I implemented the use of (numberp) function which one I wasn't aware of and it worked.
(defun val1-p ()
(if [b](or  (not (numberp (read (get_tile "text_dcl")))) (<= (read (get_tile "text_dcl")) 0))[/b]
  (set_tile "error" "Text Height invalid!")
  (mode_tile "text_dcl" 2)
);progn
(progn (if (< (read (get_tile "offset_dcl")) 0)
                 (set_tile "error" "Text Offset invalid!")
                 (mode_tile "offset_dcl" 2)
               );progn
          (done_dialog)
           );progn
);defun
"text_dcl")) 0))
Using this I can avoid negative numbers, zero and letter input.
NOTE:
No need for (progn .. in condition statement...
NOTE:
Correct ,
Thank you pBe :thumbsup:
  • 3 years later...
Hello everybody:
i need some help, please..
i have a "Edit Box" where I get the project number (automatic) from the CADD files the user try to open it,
but sometimes the user need to input the project number, and I need to make sure is not a consecutive or
similar repetitive numbers as sample 123456789, 0000000, 11111 etc.
this is what I have in the LISP file...
(if (numberp (read (get_tile "rd_PN")))
(setq v1 (get_tile "rd_PN"))
(done_dialog)
(progn (alert "Please NUMBERS ONLY..!!")
(mode_tile "rd_PN" 3)
and in the DCL file...
: edit_box {
alignment = left;
key = "rd_PN";
edit_width = 10;
allow_accept = true;
somebody have an idea how to accomplish this....?
Thank in advance, for your help...
DC
select
Test the following for your reference:
(< 1 2 3 4)
(= 1 1 1 1)
Sorry, it must be complete as the following:
(defun deal (str opr / new rtn)
 (setq new "")
 (if (vl-every
       '(lambda (i) (numberp (read (chr i))))
       (vl-string->list str)
   (while (and str (/= str ""))
     (setq
       new (strcat new (substr str 1 1) " ")
       str (substr str 2)
 (and
   (/= new "")
   (setq rtn (opr (read (strcat "(" new ")"))))
 rtn
Usage of the code:
Is equal:
(deal  "1234567" =)
Or is Smaller than:
(deal  "1234567" <)
@Tharwat:
_$ (deal  "-1234567" =)
nil
_$ (deal  "12.34567" =)
Error: misplaced dot on input
_1$
This thread has some helpful material (reply #2 by marko_ribar).
@Tharwat:
nil
_1$
@Grrr, you need to read what DaveC is asking for and what is their case as they have described it above. ;)
Oh, sorry about that!
In DaveC's shoes I would compare the user input against a list of actual project numbers.
@Tharwat:
You idea can be shortened to:
(defun TestString (str opr)
 (and
   (not (wcmatch str "*[~0-9]*"))
   (apply opr (vl-string->list str))
Note: The functions are not checking if the digits are in sequence:
(deal "1234" <) => T
(deal "1489" <) => T
More clarity is required on what constitutes a valid input - this may be too strict:
(defun validate ( str )
   (and (wcmatch str "~*[~0-9]*")
        ((lambda ( lst ) (vl-some '(lambda ( a b ) (< 1 (abs (- a b)))) lst (cdr lst))) (vl-string->list str))
As well as yours. :)
_$ (TestString "1489" '<)
T
Thank you Tharwat, that work well....
So I will create a COND statements for the different options...
Thank a lot again...
