Suresh968 Posted June 3, 2013 Posted June 3, 2013 Hello there, I had developed a Batch Plot Utility software in Visual Basic using AutoCAD 2005 Type Library in 2006 (XP). I didn't use it in last 7 years. Now I want to use it along with AutoCAD 2010 / 2007 in windows 7; but it's not working . How am I suppose to work with it as I don't have the source code, to re-reference the new library. Please, Help Quote
Suresh968 Posted June 7, 2013 Author Posted June 7, 2013 Well, that is not a better option. Because, I don't have the VB6 now and I've never used the newer version; so going with this option is rather time consuming for me. I hoped to get some help here anyway. Quote
Tyke Posted June 7, 2013 Posted June 7, 2013 If you are using AutoCAD 2007 LT, as your Profile shows, then you can save yourself a lot of time because LT cannot run a VB6 or any other similar program. You could always do it using a script or DIESEL. Quote
