Paste clipboard text to active window of a vertical product?
Hello every body,
I don't know exactly if is the right forum.
I Run an autocad vertical product, it has a certain window containing a selected combobox .I need a program that detect that the active window is the one wanted and paste from clipboard automatically to the selected field (comobox).
More information is needed (i.e., Screen Shot(s), what vertical product [Revit MEP, AutoCAD MEP?], what combobox of what form [your own custom form, or an internal built-in form?], etc.).
I have already the text in the clipboard, i want it to be pasted automatically to the field entitled "Room Name" ,the window in concern is an internal form not mine.
If the internal form is Modal (which it appears to be), then the only way you can 'paste' a string value from clipboard is through a mouse, or keyboard macro, presuming that the desired field is the first available field to receive a supplementary macro invocation.
Hope that makes (more?) sense to you.
Thank you,
How to do it with macro?
A mouse, or keyboard macro is a single keystroke substitution (usually) for actually pressing Ctrl+V... This mouse, or keyboard macro is only performed by hardware that supports this functionality (i.e., Logitech G700, G510, etc.).
I got the following Routine
Sub PasteFromClip()
AppActivate ("Room Information Management")
Application.SendKeys ("^v")
End Sub
I you can help run it automatically when the window named "Room Information Management" appear on screen.
Firstly, please use
[quote name='fathihvac']
[code]
Sub PasteFromClip()
End Sub
Thanks for correcting my statement above :oops:... I love learning new things.
For completeness, which Event are you hooking to call your PasteFromClip() Method when the "Room Information Management" dialog is activated? :unsure:
I am not good at coding but i want to run the paste command when the "Room Information Management" dialog is activated.
