Viewport won't display object color
adrath
I'm having an issue with viewports in a drawing not displaying the color of the objects in model space. All of the objects are set to display bylayer, and all of the viewport overrides in the drawing are off. Still, the objects will only display as either white or grey through the viewport, even though the colors show up fine in model space. I've also tried making a new viewport and it also displays everything as either white or gray, so I'm thinking it might be some kind of system variable that I don't know about. Anyone have any ideas? Thanks!
Run the PAGESETUP command.
Modify the current pagesetup (or the named one assigned to that layout)
UNcheck the "Display plot styles" checkbox in the upper right corner (next to the plot style table drop-down)
