What better way to store points in a vector and
then grab a determinda position:
ADD VALUES:
maxvector[].add(2761.11 1898.11 0.0)
maxvector[].add (3761.12 1538.43 0.0)
maxvector[].add(4761.15 2598.58 0.0)
RESULT:
maxvector[]
0 = (2761.11 1898.11 0.0)
1 = (3761.12 1538.43 0.0)
2 = (4761.15 2598.58 0.0)
And then a way to get this value at a given position
Ex:
(print maxvector[1])
RESULT:
Edited by rodrigo_sjc_sp
Use a list:
(setq maxvector
Then:
(nth 1 maxvector)
Lee ,
Using your sample
(setq maxvector
How to add a new value(point) in maxvector via lisp ?
(setq maxvector (cons '(3411.11 9418.11 0.0) maxvector))
PS: Please edit your post and enclose your code with code tags:
[highlight][noparse]
[/noparse][/highlight] Your code here [highlight][noparse]
:)Thank you, now fix the tags
Lee, how can I get the value using a variable?
(setq counting 1)
(nth counting maxvector)
ok lee, is that I am using this code and it is returning a wrong position,
should be something of the logic then.
thank you:ouch:
Remember that the indices for the nth function are zero-based (i.e. the first item is at index 0), and that the cons function will add a new item to the start of the list.
How do I remove an item from the vector? example.....remove item 3 of vector
ex:
(maxvector remove 3)
Consider a 'Remove Nth' function:
;; Remove Nth  -  Lee Mac
;; Removes the item at the nth index in a supplied list
(defun LM:RemoveNth ( n l )
   (if (and l (< 0 n))
       (cons (car l) (LM:RemoveNth (1- n) (cdr l)))
       (cdr l)
Or iteratively:
(defun LM:RemoveNth ( n l / i )
   (setq i -1)
   (vl-remove-if '(lambda ( x ) (= (setq i (1+ i)) n)) l)
(LM:RemoveNth 3 maxvector)
Thanks lee
I made a change in my code using the CDR function
     (setq maxvector (cdr maxvector))
The result excludes the first item, it was what I needed
Thanks
