JayDee0414 Posted June 5, 2013 Posted June 5, 2013 (edited) This is a very simple lisp routine to convert TEXT into MTEXT using EXPRESS>TOOLS>TXT2MTXT command. Adding background mask without lisp. Use SSX select one mtext. Properties dialog box click on Select object. At the prompt Select objects: press P for previous selection. In the dialog box under TEXT select Background masking and set it for the all selected MTEXT entities. (defun c:tx2mt01 () (setq p (ssget)) ;filter could be used. In that case you dont need (if (= "TEXT" (dxf 0 e)) ; ;statement ;(if (setq p (ssget "_x" (list'(0 . "TEXT") (cons 8 "LAYER NAME")))) ;(progn (setq l 0 n (sslength p)) (while (< l n) (setq e (entget (ssname p l))) (if (= "TEXT" (dxf 0 e)) (Command "TXT2MTXT" (dxf -1 e) "") ) (setq l (1+ l)) (prompt ".") ) (princ) ) (defun DXF (VAL E) (cdr (assoc VAL E)) ) (princ) Edited June 5, 2013 by SLW210 Quote
SLW210 Posted June 5, 2013 Posted June 5, 2013 Please reade the Code posting guidelines and use Code Tags for your code. I fixed it for you this time. Quote
