Hi everyone,
I'm looking for a lisp for special numbering:
BGDT/001
BGDT/002-003
BGDT/004
BGDT/005
BGDT/006-007...
So the lisp need to "identify" when the text ending with 1 number (BGDT/001)
an when the texte ending with 2 numbers (BGDT/002-003).
I will make a block with attribute for numbers with 1 number (BGDT/xxx)
And a block with attribute for numbers with 2 numbers (BGDT/xxx-xxx)
And now with a lisp (like increment) if i select one of the text, he can recognise if it's with 1 or 2 numbers...for sample:
BGDT/xxx ---- when a click ---- BGDT/001
BGDT/xxx-xxx -- when a click ---- BGDT/002-003...and so far.
Possible? :?
Thanks for answer...
Bono.
  • Replies 20
  • bono05
    11
  • pBe
    7
  • Tharwat
    3
This lisp to check for numbers .
(defun c:Test (/ ss n e p)
 (if (progn
       (princ "\n Pick only one Attibuted Block :")
       (setq ss (ssget "_+.:S" '((0 . "INSERT") (66 . 1))))
     (setq n (entnext (ssname ss 0)))
     (while (not (eq (cdr (assoc 0 (setq e (entget n)))) "SEQEND"))
       (if (and (eq (cdr (assoc 0 e)) "ATTRIB")
                (setq p (vl-string-position 47 (cdr (assoc 1 e))))
         (if (vl-string-position 45 (cdr (assoc 1 e)) (1+ p))
           (alert "The selected Block has two Numbers !")
           (alert "The selected Block has only one Number !")
         (alert
           "The selected Block has no < / > to check for Numbers !"
       (setq n (entnext n))
Woaw.....very fast answer!! thanks Tharwat.
So i made a few block with attribute BGDT/xxx and BGDT/xxx-xxx.... i'll put manually the first one to BGDT/001 and then i try de lisp...and at the end i receive this alert "The selected Block has no to check for Numbers !".
And how to make increment?
I don't know the problem...:(
Just upload a sample drawing with these blocks and mention what you want from the lisp to do , so I might be able to help or anyone else may also have the willing to help you as well .
Ok!
As you can see i have a plan with blocks/attribute:
Block Data1 with attribute and one ending number (BGDT/xxx)...xxx is the ending number.
Block Data2 with attribute and two ending numbers (BGDT/xxx-xxx) xxx-xxx are the ending numbers
So i need to increase those numbers from 001 to 200 or more...
Actually i'm using incr.lsp to increase my numbers but he's only working with one ending numbers...evrytime i select a atrribute he made +1.
But in this case i need a lisp who can made from two ending numbers a logical suite.
For sample when i select de first one with xxx...he made 001...and if the second one has xxx-xxx...he made 002-003....
TEST.dwg
Try this routine and let me know how did the code work for you .
(defun c:Test (/ _inc ss n i e p s en j k)
 ;;--== Tharwat 06. 06. 2013 ==--;;
 (defun _Inc (n / o)
   (cond ((< n 10) (setq o (strcat "00" (itoa n))))
         ((<= n 99) (setq o (strcat "0" (itoa n))))
         (t (setq o (itoa n)))
   o
 (if (progn
       (princ "\n Select Attibuted Blocks :")
       (setq n  0
             ss (ssget "_:L" '((0 . "INSERT") (66 . 1)))
       (setq en (entnext (ssname ss (setq i (1- i)))))
       (while (not (eq (cdr (assoc 0 (setq e (entget en)))) "SEQEND"))
           (if
             (setq s (vl-string-position 45 (cdr (assoc 1 e)) (1+ p)))
                (setq n (1+ n)
                      j (_inc n)
                      n (1+ n)
                      k (_inc n)
                (entmod
                  (subst
                    (cons 1
                          (strcat (substr (cdr (assoc 1 e)) 1 (+ 1 p))
                                  j
                                  k
                    (assoc 1 e)
                    e
                (setq n (1+ n))
                (entmod
                  (subst
                    (cons 1
                                  (_inc n)
                    (assoc 1 e)
                    e
         (setq en (entnext en))
We go forward!!!!
Can you do somethings to see number(s) each time i select a attribute? So i can really follow my result.
Actually i need to select all attribute and then i can see the results.
Also actually the last attribute give me the first number? Better the first attribute ----> first number.
THANKS!!!!!
(Defun c:IT  (/ ZeroPref  ss two att names)
(vl-load-com)
(defun ZeroPref  (str)
           (strcat (nth (strlen str) '(x "00" "0" "")) str)
[color="blue"];;;	Add your blocknames here			;;;
(setq Names (list
;;;	IF the block only have one number add here	;;;
                 '("PRISE-M120" "PRISE-M150" "PRISE-SR" )
;;;	if the block has two numbers add it here	;;;
                   '("PRISE DOUBLE WIFI 1"
                     "PRISE-D" "PRISE-DR"
                     "PRISE-P"))
                        )      [/color]
(setq qstr  (getstring
         (strcat "\nEnter Prefix <"
                 (cond (prefx)
                       ("BGDT"))
prefx (cond ((/= qstr "") (strcase qstr))
         (prefx)
         ("BGDT"))
(setq num  (cond
              ((getint
                     (strcat "\nEnter Start number"
                             (if num
                                   (strcat " <"
                                           (ZeroPref
                                                 (itoa num))
              (num))
     (While (and (princ (strcat "\nCurrent number "
                                (ZeroPref (itoa num))))
                 (setq two nil
                       ss  (ssget
                                 "_:S:L"
                                 ([color="blue"]list '(0 . "INSERT")'(66 . 1)
                                 (cons 2 (apply 'strcat
                                               (mapcar '(lambda (d)
                                                (strcat  d ","))
                                                     (apply 'append
                                                            names)))))))[/color])
           (if (Setq att (vl-some
                         '(lambda (j)
                                (if (eq (vla-get-tagstring j) "NR") j))
                         (vlax-invoke
                               (setq e (vlax-ename->vla-object
                                     (ssname ss 0)))
                               'GetAttributes))
		[color="blue"](setq two (member
                                        (vla-get-effectivename e)
                                       (cadr Names)))[/color]
            (vla-put-textstring att
                  (strcat prefx "."
                          (if two
                                (strcat (ZeroPref (itoa num))
                                       (ZeroPref (itoa (1+ num))))
                                     (ZeroPref (itoa num)))))
            (setq num (+ (if two 2
                               1)
                         num))))
Edited by pBe
UPDATE CODE
pBe,
That's the way i'm looking for!!!!!!
Is that right if it's not BGDT/ but ABCD/ (for sample), i just need to change this here: (strcat "BGDT/"
Can you insert a line to have a popup who ask me "text before number" and "insert first number"?
Because BGDT/ was a sample... but there are different zone and so different text before the number. So i don't need to change the lisp and reload the lisp each time.
If not your lisp is already GREAT for me!!!
Thanks!
pBe,
Thanks!
[/b]
You are welcome bono05 :)
Remember this code will work specifically for blocks "Data1" & "Data2" with tags "G" & "A" found on your test drawing attachment.
Happy to help.
IT.lsp work perfect for me....
But there is no other way than this: this code will work specifically for blocks "Data1" & "Data2" with tags "G" & "A"
Because that was a sample...and it will be more than two differents blocks on the plan. Problem i'm still waiting for the plans. :oops:
Can you make that this lisp working for each block and each tag?
THANKS YOU!!!!!!
Thanks!!!
Yes we can its really easy.
These are the lines you need to change:
(2 . "Data1,Data2");
("A" "G");
Tell you what bono05 we'll cross the bridge when we get there okay? : [i'll be here]
Note: i wrote it that way [block and TAG specific] to make do without reading the current value for determining if the "numbers" is one or two.
OK i understand....is there a possibilities to have 6 differents blocks "data1, data2,....data6" with tags "A,B,C,D,E,F" that i can change easily into the lisp? :unsure:
Again, Yes...[but its more than just that really] i just need to see what you have... unless you know how to modify it yourself then by all means do so. :)
Catch you later bono05
  • 2 years later...
Hi PBe (and all others),
Concerning It.lsp....
It's possible to "add" an option for block with 3 numbers and block with 4 numbers?
It would be fantastic for me because i need it for a large project.
Thanks a lot!
Bono
Thanks a lot!
Bono
(Defun c:IT  (/ _numbers ZeroPref  op ss two att names)
;;;		pBe Jun 2013		;;;
;;;		pBe Apr 2016		;;;
(vl-load-com)
(defun _numbers (int m / l)
 	(repeat m
  (setq n (ZeroPref (itoa int)))
  (setq l (cons (Strcat "-" n ) l)
	int (1+ int)))
 (list (substr (apply 'strcat (reverse l)) 2) int)
;;;		Block Names Here	;;;
[color="blue"]	(setq Names '(
	    (("PRISE-M120" "PRISE-M150"
     		"PRISE-SR" "PRISE-SP"
    		 "PRISE-S" 		)	1	)
           (("PRISE DOUBLE WIFI 1" "PRISE-D"
      		"PRISE-DR" "PRISE-P"
    					)	2	)
;;;	if the block has three numbers add it here	;;;
	    (("BLOCKNAMEFOR3"
	    				)	3	)
;;;	if the block has four numbers add it here	;;;
	    (("BLOCKNAMEFOR4"
	    				)	4	)
      )[/color]
(setq qstr  (getstring (strcat "\nEnter Prefix <"
                 (cond (prefx)
                       ("BGDT"))
	          (prefx)  ("BGDT"))
(setq num  (cond
              ((getint (strcat "\nEnter Start number"
                             (if num (strcat " <"
                                           (ZeroPref
                                                 (itoa num))
                             ))) (num)))
                 (setq ss (ssget  "_:S:L" '((0 . "INSERT")(66 . 1)))))
           (if (And
		[color="blue"](setq ef (strcase (vla-get-EffectiveName (setq e (vlax-ename->vla-object
                                      		(ssname ss 0))))))
		(setq op (vl-some '(lambda (k) (if (member ef (car k)) (Cadr k))) Names))[/color]
		(Setq att (vl-some
                          '(lambda (j)
                          (vlax-invoke e 'GetAttributes))
			  (setq r (_numbers num op) s (car r) num (cadr r))
			  (vla-put-textstring att (strcat prefx "." s))
      		(princ "\n <<<Not a valid block >>>"))
clydE 2.dwg
EDIT: Clear on what the OP meant by "...block with 3 numbers and block with 4 numbers?.."
Edited by pBe
That's great !!!
Now it's my fault...but i have a block (3 numbers) but with 4 attributes! And of course It.lsp change only the first one...See sample dwg.
Is there a solution? Once again i'm sorry to forget this...
Drawing_test.dwg
That's great !!!
Now it's my fault.......
You are right about that dude :lol:
.....but i have a block (3 numbers) but with 4 attributes! And of course It.lsp change only the first one...
Because that's from all the other samples you sent & posted.
Of course there is, but i wish you think about ALL the conditions before you request for modifications bono05.
(Defun c:IT  (/ _numbers ZeroPref  op ss  att names)
(vl-load-com)
 	(repeat m
	int (1+ int)))
;;;		Blcok Names Here	;;;
(setq Names '(
    		 "PRISE-S" 		)	1	)
    					)	2	)
	    (( "ST-VLOERDOOS_2"
	    				)	3	)
	    (("BLOCKNAMEFOR4"
	    				)	4	)
                 (cond (prefx)
                       ("BGDT"))
	          (prefx)  ("BGDT"))
(setq num  (cond
                                           (ZeroPref
                                                 (itoa num))
                             ))) (num)))
           (if (And
                                      		(ssname ss 0))))))
		[color="blue"](setq att (vl-remove-if-not '(lambda (j)
                                 (if (eq (vla-get-tagstring j) "NR") j)) (vlax-invoke e 'GetAttributes)))[/color]
    [color="blue"]  (foreach itm att
			  (vla-put-textstring itm (strcat prefx "." s))[/color]
I can believe what i see :roll: It's AMAZING !!!!
And with the block with 4 attributes ...Don't need to click on each attributes separately, one click and it's done!!!!!!
1000000x Thank you Pbe!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
