Change all dimensions from mm to inch in drawing
Hi guys,
our customers want to have a lot of drawings with inch dimensions. I'm the man who should convert all the old drawings to the new style. The dimensions should look like 22.13" (562.12mm). For now we have have only 562.12 in metric system.
Is there a way to to this automatically?
Greets,
Bullfrog
yes
goto your dimension style(s) and turn on dual dimensioning. You will need a conversion factor (25.4 or whatever 1/25.4 is) and all should update. You may need to drag some dimensions around to make more room but generally its painless.
Dave,
thanks for the tip. That brings me now 562.12 [22.13"]. But I need:
22.13" (562.12mm)
another idea?
thx
change your measurement scale for "actual" dimensions to 25.4 and your alt to 1? I also use suffixes to ensure I know which are mm and which are "
Yeah that works fine. How can i copy this to all other dims on the drawing?
if you change all the styles (provided your dims are associated) all dimensions should update.
Hi again,
now i have created this without your last trick:
22.13" [562.12mm]
Is there a way to change the brackets?
I changed all this stuff in my main dimstyle for linear and diameter dimensions. i found an option in express/dimensions/import and export dimstyle. But when i try to import the dimstyle in another dwg nothing happens. There is a new dimstyle in the dimstyle-options dialog, but thats it. Any ideas?
Hi again,
22.13" [562.12mm]
make sure your crrent dimstyle is the new one, type dim, then update, then cross every thing in the drawing (enter). they should all update no?
Doesn't work. When I do this all of the dimensions get very small and nothing else happens. But I think thats a problem produced by the guys who made the drawings...
But what about the [] Brackets for the alternative unit. Is there a way to change them into ()?
Thanks
BulLfrog
Thanks
BulLfrog
I don't believe so my friend... well not without code anyway
Thanks
BulLfrog
I never use alternative unit to change mm,cm,m to inches or inches to mm,cm,m coz i hate this [] Brackets.You can do with "scale factor" under
"primary units" tab from Dim style Dialog box.Then you can see dim with mm suffix.I did for you sample dwg with 3 dim style.(mm,ft,ft with scale factor) and show sample.Pls check mate!
mm to inches.dwg
I never even heard of Myanmar before now and it's a country!!!! :oops: Well you learn something new every day....
Thanks
BulLfrog
[] brackets are the standard, don't know of a way to change [] to (). And why would anyone need to? :?
Thank for your notice me fri!:):)
  • 11 months later...
Dimension settings for alternate units without the [ brackets ]
NOTE the values for: DIM SUFFIX mm\X\f ALT PREFIX ; ALT SUFFIX \f
Do you know where I can find a list of these variables? I searched through the AutoCAD help files but can't find them.
I am not sure, but if you have something you are looking for, I can try to help.
( ) instead of [ ]
In the Primary Units set:
dim Suffix: = mm\X\f
In the Alternate Units set:
dim Prefix = ;(
dim Suffix = )\f
  • Remove mm if you do not want it to say mm after your dimension. This is for metric units
Remove [ ]
dim Prefix = ;
dim Suffix = \f
Note: If your dimension has fractions in front and in back of your dimension and it is not suppose to be there, change your font!
( ) instead of [ ]
dim Prefix = ;(
dim Suffix = )\f
