dsibbo Posted June 10, 2013 Posted June 10, 2013 Can anyone help me with an alignment parameter I have on a radiator block. I never created the block myself but it is pretty good so I use it. The block is a radiator withn an alignment parameter which allows me to click the point and place it on a wall. The radiator then changes to suit the alignment of the line. The only problem is sometimes the block aligns with the line but goes the wrong side. Therefore sitting the radiator within the wall lines and not in the room. Is there a keyboard button or something which switches between the sides of the line you are aligning to so I can choose between the correct one. Thanks Quote
SLW210 Posted June 10, 2013 Posted June 10, 2013 See if reversing the polyline works, other than that, you will need to post the block. Quote
feargt Posted June 10, 2013 Posted June 10, 2013 when you are inserting the block, take note of which side of the line you are approaching from to select the point on the line, that usually dictates which side of the "wall" it will be placed. Quote
