JBurnett Posted June 12, 2013 Share Posted June 12, 2013 For example: I made trusses and blocked them, they appear on the roof in isometric view; however I'm trying to do a vertical section view and the trusses do not appear. When looking at the floor plan, the trusses appear in bottom view instead of top view. When I ran into this problem with a roof wall, I simply changed to override cut plane in the object display properties. I don't see this option for my blocked trusses. Any ideas? Quote Link to comment Share on other sites More sharing options...
steven-g Posted June 13, 2013 Share Posted June 13, 2013 Can you attach a drawing, it makes it much easier to understand. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 13, 2013 Share Posted June 13, 2013 This sounds like an Architecture specific question. Are these actual AutoCAD blocks or objects created by Architecture? Quote Link to comment Share on other sites More sharing options...
JBurnett Posted June 13, 2013 Author Share Posted June 13, 2013 Thanks, but I ended up redoing my work and I don't have the problem any more. Quote Link to comment Share on other sites More sharing options...
