daha Posted June 13, 2013 Posted June 13, 2013 I am trying to modify an existing lisp routine to include a function for the user (that's me) to cancel running the routine. When the lisp is running, there seems to be no way to cancel it. (and for a large dwg it can take a long, long time to finish) I wouldn't think you'd have to code an exit or quit function in a program, but apparently for this one I do because the only way to quit is to CTRL+SHFT+ESC and kill the ACAD process. Thx. Quote
rkmcswain Posted June 13, 2013 Posted June 13, 2013 Is your code running a loop or something? What else is keeping that function running so long? Quote
BlackBox Posted June 13, 2013 Posted June 13, 2013 Sounds like processing a large data set... Perhaps due to inefficient code (not sure, because none was posted). In any event, Ctrl+Shift have nothing to do with it, only when you hit Esc did the routine stop due to built-in (or localized) *error* handler. Quote
irneb Posted June 14, 2013 Posted June 14, 2013 In any event, Ctrl+Shift have nothing to do with it, only when you hit Esc did the routine stop due to built-in (or localized) *error* handler.I think the OP means Ctrl+shift+Esc opens the Task Manager, from which he then terminates the acad.exe process. But yes, there's probably something going wrong inside the Lisp. Perhaps a loop which never finishes, or code running extremely inefficiently / through too many iterations. We can only say for sure if we can see the code - so waiting for the OP to return with some more info. Quote
pBe Posted June 14, 2013 Posted June 14, 2013 Sounds like processing a large data set... Perhaps due to inefficient code (not sure, because none was posted). But yes, there's probably something going wrong inside the Lisp. Perhaps a loop which never finishes, or code running extremely inefficiently / through too many iterations. We can only say for sure if we can see the code - so waiting for the OP to return with some more info. Agreed, its the most likely culprit. 1+ Quote
daha Posted June 18, 2013 Author Posted June 18, 2013 (edited) Sorry, here is the code. I put this in a macro to run when closing out a dwg. But, if I run the code on a large dwg set (150+) layouts it's murderous. When I try to cancel it using ESC, it doesn't do anything. So, I have to wait an hour or kill the process. It's not a big deal if I have time, but if I forget and I need to save the drawing (like I just did), then I'm screwed. I have to allow it to complete in order to save my changes. (vl-load-com) (defun c:zza (/ *error* oldCtab) (defun *error* (msg) (and oldCtab (setvar 'ctab oldCtab)) (cond ((not msg)) ; Normal exit ((member msg '("Function cancelled" "quit / exit abort"))) ; <esc> or (quit) ((princ (strcat "\n** Error: " msg " ** "))) ; Fatal error, display it ) (princ) ) (if (and (setq oldCtab (getvar 'ctab)) (setq acApp (vlax-get-acad-object)) ) (foreach tab (layoutlist) (setvar 'ctab tab) (vla-zoomall acApp) ) ) (*error* nil) ) Edited June 18, 2013 by rkmcswain Added [CODE] tags Quote
BlackBox Posted June 18, 2013 Posted June 18, 2013 Sorry, here is the code. I put this in a macro to run when closing out a dwg. But, if I run the code on a large dwg set (150+) layouts it's murderous. When I try to cancel it using ESC, it doesn't do anything. So, I have to wait an hour or kill the process. It's not a big deal if I have time, but if I forget and I need to save the drawing (like I just did), then I'm screwed. I have to allow it to complete in order to save my changes. (vl-load-com) (defun c:zza (/ *error* oldCtab) (defun *error* (msg) (and oldCtab (setvar 'ctab oldCtab)) (cond ((not msg)) ; Normal exit ((member msg '("Function cancelled" "quit / exit abort"))) ; or (quit) ((princ (strcat "\n** Error: " msg " ** "))) ; Fatal error, display it ) (princ) ) (if (and (setq oldCtab (getvar 'ctab)) (setq acApp (vlax-get-acad-object)) ) (foreach tab (layoutlist) (setvar 'ctab tab) (vla-zoomall acApp) ) ) (*error* nil) ) I thought ^that^ looked familiar. ... So why not just check for unsaved changes first? (vl-load-com) (defun c:ZoomAll (/ *error* oldCtab acApp mspace) (defun *error* (msg) (and oldCtab (setvar 'ctab oldCtab)) (cond ((not msg)) ; Normal exit ((member msg '("Function cancelled" "quit / exit abort"))) ; <esc> or (quit) ((princ (strcat "\n** Error: " msg " ** "))) ; Fatal error, display it ) (princ) ) (if (= 0 (getvar 'dbmod)) (if (and (setq oldCtab (getvar 'ctab)) (setq acApp (vlax-get-acad-object)) ) (foreach tab (layoutlist) (setvar 'ctab tab) (if (setq mspace (< 1 (getvar 'cvport))) (vla-put-mspace acDoc :vlax-false) ) (vla-zoomall acApp) (if mspace (vla-put-mspace acDoc :vlax-true) ) ) ) (prompt "\n** Unsaved changes, save and try again ** ") ) (*error* nil) ) Quote
BlackBox Posted June 18, 2013 Posted June 18, 2013 ... a large dwg set (150+) layouts [PeteCampbellVoice] ... A thing like that. [/PeteCampbellVoice] #MadMen Quote
fixo Posted June 18, 2013 Posted June 18, 2013 Probably will be quickier when iterate through layouts, instead of: (foreach tab (layoutlist) .... ) use this: (setq olayouts (vla-get-layouts doc)) (vlax-for olayout olayouts ;|rest code here|; ) Not tested Quote
alanjt Posted June 18, 2013 Posted June 18, 2013 I recently changed mine to this: (defun c:ZAL (/ ctab) ;; Zoom extents of viewport in All Layouts (excluding Model) ;; Alan J. Thompson (or *Acad* (setq *Acad* (vlax-get-acad-object))) (or *AcadDoc* (setq *AcadDoc* (vla-get-activedocument *Acad*))) (setq ctab (getvar 'CTAB)) (foreach layout (layoutlist) (setvar 'CTAB layout) (vla-put-mspace *AcadDoc* :vlax-false) (vla-zoomwindow *Acad* (vlax-3d-point (getvar 'LIMMIN)) (vlax-3d-point (getvar 'LIMMAX))) ) (setvar 'CTAB ctab) (princ) ) Quote
3dwannab Posted June 12, 2025 Posted June 12, 2025 Does anyone want to test setting these 3 variables to the top to the best performing. I notice it a lot better. (vl-load-com) ;; https://www.theswamp.org/index.php?topic=53336.msg585756#msg585756 ;; Zoom Extents All Layouts ;; Mod by 3dwannab on 2025.06.12 to try turning regen variables to the best performing. (defun c:ZEAL (/ app doc restore) (command "REGENAUTO" "OFF") ;; Obsolete. Controls automatic regeneration of a drawing. But stick it in there anyway (setvar "LAYOUTREGENCTL" 2) ;; 0 = The drawing is regenerated each time you switch tabs. 1 = For the Model tab and the last layout made current, the display list is saved to memory and regenerations are suppressed when you switch between the two tabs. For all other layouts, regenerations still occur when you switch to those tabs. 2 = The drawing is regenerated the first time you switch to each tab. For the remainder of the drawing session, the display list is saved to memory and regenerations are suppressed when you switch to those tabs. (command "RTREGENAUTO" "OFF") ;; 0 = Prevents automatic regeneration when panning and zooming. 1 = Allows automatic regeneration when panning and zooming. (setq app (vlax-get-acad-object) doc (vla-get-activedocument app) restore (vla-get-activelayout doc) ) (vlax-for layout (vla-get-layouts doc) (vla-put-activelayout doc layout) (if (or (eq 1 (getvar 'tilemode)) (eq 1 (getvar 'cvport))) (vla-zoomextents app) (progn (vla-put-mspace doc :vlax-false) (vla-zoomextents app) (vla-put-mspace doc :vlax-true) ) ) ) (vla-put-activelayout doc restore) (command "REGENAUTO" "ON") (setvar "LAYOUTREGENCTL" 2) (command "RTREGENAUTO" "ON") (princ) ) 1 Quote
