BHAus Posted June 13, 2013 Posted June 13, 2013 Hi everyone, I have made an excel sheet that generates new drawings based on a template. It can open and save the new drawing using objectDBX, but my code to change the attribute values and text will not work. At this stage, I have turned off the dbx and am just using an open and save application, but it is slow. Can anyone point me in the right direction as to the changes I need to make on the following: For Each oEntity In oACAD.ActiveDocument.ModelSpace If TypeOf oEntity Is AcadBlockReference Then Set oBlockRef = oEntity If oBlockRef.HasAttributes Then For Each varAttribRef In oBlockRef.GetAttributes Select Case varAttribRef.TextString Case strFindval varAttribRef.TextString = strFillval End Select Next varAttribRef End If End If Next oEntity Any help or directions towards an ObjectDBX information link would be much appreciated. Brett Quote
SLW210 Posted June 14, 2013 Posted June 14, 2013 Please read the Code posting guidelines and edit your post to include the Code in Code Tags. Quote
