sinnerboy Posted June 17, 2013 Posted June 17, 2013 This is a problem I have been encountering ever since Acrobat Reader 6.0 was launched . You use the AutoCAD wipepout command ( one of my favorites) . You make a PDF - it looks fine. You print that PDF and you get either a solid block fill where you placed wipeouts or you get heavy zebra stripes. Open the PDF using Reader release 5 - and you get a perfect print . Anybody else confronted this issue with a better work around than keep a Reader version 5 installed on your PC ? (Version 11 still "fails" ) Quote
Organic Posted June 17, 2013 Posted June 17, 2013 I remember that issue. The solution is to not use wipeouts. Instead you can use a colour 255,255,255 solid hatch to mask anything instead. Quote
mech Posted June 17, 2013 Posted June 17, 2013 good tip organic!! I use Wipeouts too but it's always a pain having to turn the things on every time I open a drawing!! I may change my ways...... Quote
pqphillips Posted June 17, 2013 Posted June 17, 2013 I remember having a similar problem at work once. The solution was, I believe, to use the actual Adobe PDF printer option in the plot dialogue as opposed to AutoCAD's PDF print option. Quote
sinnerboy Posted June 18, 2013 Author Posted June 18, 2013 Thanks for the responses folks , much appreciated . I'll give each suggestion a try over the next little while. Quote
Chilidawg Posted June 24, 2013 Posted June 24, 2013 If you have a large number of wipeouts, you can set the wipeout color to 255,255,255. Hatching at 255, 255, 255 is a slightly better method, however, as wipeouts are raster objects and take up more file space. Quote
FishrOfGrizz Posted June 19, 2020 Posted June 19, 2020 On 6/17/2013 at 3:06 AM, Organic said: I remember that issue. The solution is to not use wipeouts. Instead you can use a colour 255,255,255 solid hatch to mask anything instead. This was very helpful. What was the key was the color 255,255,255. Because I just changed the wipeout layer color to 255,255,255 and it worked great. This way you can still use the wipeout feature without any problems in the print. Quote
