ibach Posted June 17, 2013 Posted June 17, 2013 I need to use same format of a field in the attribute that is in a block. Thing is that I have an attribute in block that is describing perimeter of an area in a drawing. Problem is that, in the same drawing, sometimes .(dot) and sometime ,(comma) was used as a decimal separator. I need to change all dots to commas of such a field using a quick lisp because there are hundreds of such blocks. Please help. I know I could use Lee Mac Areas2AttributeV1-1.lsp with a little modification, but it is still too many clicks. I'd like to select attribute in one of the blocks, copy it's formatting parameters and translate them to other attributes by clicking on them, like using match properties. I must leave the object that the attribute is referenced to unchanged. Quote
neophoible Posted June 17, 2013 Posted June 17, 2013 Have you tried using _.-ATTEDIT. Here's a simple example where I replaced T with t in 4 attributes I selected using a Crossing Window. Command: _.-ATTEDIT Edit attributes one at a time? [Yes/No] <Y>: N Performing global editing of attribute values. Edit only attributes visible on screen? [Yes/No] <Y>: Enter block name specification <*>: Enter attribute tag specification <*>: Enter attribute value specification <*>: Select Attributes: Specify opposite corner: 4 found Select Attributes: 4 attributes selected. Enter string to change: T Enter new string: t Command: Quote
Dadgad Posted July 14, 2013 Posted July 14, 2013 Try my new program: Match Field Formatting Lee, that looks really useful, well done, as always. I really like that it honors the units conversion, sweet! Quote
Lee Mac Posted July 14, 2013 Posted July 14, 2013 Lee, that looks really useful, well done, as always.I really like that it honors the units conversion, sweet! Cheers Dadgad! Quote
ibach Posted July 28, 2013 Author Posted July 28, 2013 Sorry for no reply sooner. Got a really big project and very little time... hospital 45000m2... Yes that is what I need, and as always when Lee does the programming it works without a flaw. Quote
