samifox Posted June 21, 2013 Posted June 21, 2013 hi im trying to select several polylines, all their vertices coordinates to a list. for some reason the selection set show correctly the number of members but i cant call them one by one with ssname any idea? Thanks Shay (defun C:DEMO (/ pl pts sspl tpts) (setq sspl (ssget '((0 . "LWPOLYLINE")))) ;_select all polylines and assign them to a selection set sspl (setq i 1) (setq tpts 0) (while (<= i (sslength sspl)) (setq pts (mapcar 'cdr (vl-remove-if-not '(lambda (e) (= (Car e) 10) ) (entget(ssname sspl 1)) ) ) ) (setq i (1+ i)) ) (setq tpts (+ tpts pts)) ) ;_run a loop that extract all vertices from all sset members ;_loop vert list ;_create a temp line between 2 points ;_gets its length ;_get its angle ;_if the distance is less than x ;_if the angle is between w and z ;_isolate those verts ;_create a rectangle Quote
Tharwat Posted June 21, 2013 Posted June 21, 2013 The number one must be replaced with i variable (entget (ssname sspl i)) What is this for ? (setq tpts (+ tpts pts)) Quote
samifox Posted June 21, 2013 Author Posted June 21, 2013 It was I instead of 1 but still can't access any member beside 0 member Pts is point list of the poly in loop Tpts is a list that hold pts lists Quote
Tharwat Posted June 21, 2013 Posted June 21, 2013 It was I instead of 1 but still can't access any member beside 0 member Pts is point list of the poly in loop Tpts is a list that hold pts lists This .. ? (defun C:DEMO (/ pl pts sspl tpts i) (if (setq sspl (ssget '((0 . "LWPOLYLINE")))) (progn (setq i 0) (while (< i (sslength sspl)) (setq pts (mapcar 'cdr (vl-remove-if-not '(lambda (e) (= (Car e) 10)) (entget (ssname sspl i)) ) ) ) (setq i (1+ i)) (setq tpts (cons pts tpts)) ) ) ) (princ tpts) (princ) ) Quote
samifox Posted June 21, 2013 Author Posted June 21, 2013 Thanks I'm on iPad now I'll test it later Quote
