surface intesect sketch help?
hi
im trying to make some ribs for a plane wing. im having problems with just one of the ribs. ive got a plane then doing surface intersect. for some reason on this plane it isnt drawing the sketch line right. not sure why.
it should be on the brown line, most of the sketch is right its just this front section of it. any ideas whats wrong?
thanks
rob
What version of SWx?
Can you attach the file here?
Can you reproduce the behavior in a new file?
im using solidworks 2012
ive made a new assembly for the problem. its just got to parts that aernt working in. only problem is the file is still too big.
how else can i add the file?
Of course an assembly file (*.sldasm) is useless without the individual part files (*.sldprt) are they in that zip?
You can dramatically reduce a file size by rolling up the feature tree before saving and zipping.
