Fclao Posted June 24, 2013 Posted June 24, 2013 Just upgraded to Acad2013, and i find it annoying that the Offset command now shows a preview. Any tips on how to turn off the Offset Preview? Thanks Quote
ReMark Posted June 24, 2013 Posted June 24, 2013 This advice courtesy of ccowgill over at the AUGI forums. Redefine offset to be the Express Tools EXOFFSET. It works the same, possibly has even more options, and more importantly no preview. I've yet to find a system variable that controls that specific feature. Quote
Dadgad Posted June 24, 2013 Posted June 24, 2013 Welcome to CADTutor. I just did a quick search and found no system variable which would restore legacy offset behavior, nor could I find any similar command listed in the CUI. Here's hoping that ReMark's suggestion solves the issue for you. Quote
ReMark Posted June 24, 2013 Posted June 24, 2013 Well one way you could disable it would be to set DRAGMODE to Off but this then affects other commands as well. It's up to the individual user to decide if the tradeoff is worth it. Quote
Fclao Posted June 24, 2013 Author Posted June 24, 2013 Thanks, guys! will try ReMark's suggestion on using EXOFFSET instead. Quote
