philliam Posted June 25, 2013 Posted June 25, 2013 After System Restore Civil 3D 2008 start-up gives the following message: "Configuration file may be locked by another process or have been set Read Only (cfg.,bak.). Correct problem and Retry or Cancel to Error Abort Exit" Then follows with Fatal Error notice: "Unable to Process Configuration File" Any Ideas on what to do to get it to start up properly? Quote
Murph_map Posted June 25, 2013 Posted June 25, 2013 Try a repair install of Civil3D from the control panel. Quote
