pretty much why I pulled out at post #6
Is any info still missing here? can what I am asking for be done using dynamic blocks or no?
  • Replies 21
  • NightMist
    7
  • neophoible
    6
  • nestly
    4
  • dbroada
    3
Posted Images
I think it's pretty clear that not all the info has been presented. The first dwg did not indicate how things would change and had some unsymmetric aspects. The miter lines in the later images did indicate how part of it would change, but these images are obviously incomplete. You are the one to know this best. I suggested making sure all the details and variations are there at the outset before asking anyone to invest time with LISP. It sounds to me like there are some who could do this using Dynamic Blocks, but guess what? They also would want all the details and variations before doing any more work on this. So, sounds like the ball is in your court. How about it? Will you supply all the details and variations in DWGs so that it is absolutely clear what you need at the outset, or at least from here on out? That's what you should do if you want help with it. But if you just want to know if it is possible to do, then it sounds like the answer is yes.
