GPlan Posted June 28, 2013 Posted June 28, 2013 Hi all! I have a problem with creating labels in section views. In a DWG file at first they work ok, then for no reason I know I can't make new labels any more. The command works fine, but the label doesn't draw regardless of lable type or label style. Thanks for help! Quote
BlackBox Posted June 28, 2013 Posted June 28, 2013 It sounds like your Section labels are configured to come in on a specific layer, or are comprised of entities on a specific layer(s) which may be frozen/off. A quick way to test this, is to thaw and turn on all layers... If your labels show back up. Also, see what label style is set be be default for that command, if there was a change there, that could explain why some labels show, and new one's do not. Yet another possibility is annotation scale. Quote
