AutoCad 2010 & AutoCad Mechanical 2010 Dimension Question.
Guest RODDY1
Hi Everyone
I need help regarding the following:
In AutoCad 2010 when I create a dimension , I can then use snap to any part of the dimesion geometry without first exploding the dimension. For Instance I can pick up the mid point of the dimesion line etc.
In AutoCad Mechnical 2010 when I create a dimension , I can NOT then use snap to any part of the dimesion geometry without first exploding the dimension.
Is this a SETVAR setting ?
Thanks for any help
Regards.
Alan
There is a filter to exclude dimensions in your Power Snap Settings, uncheck it.
Guest RODDY1
Thanks Nestly
Struggling to find the power snap settings in AutoCad Mechnical 2010
Please help
Regards.
Alan
