wimal Posted July 3, 2013 Posted July 3, 2013 I have drawn same multyline ( style 1) in two differance layers. Now I need to change the multyline style Type 1 to Type 2 in one layer without affecting to the other layer style. Is thear a quick way to do this. Quote
Dadgad Posted July 3, 2013 Posted July 3, 2013 You could do this any number of ways. One would be by using the FILTER command and then applying the change to the filter selected set in QUICK PROPERTIES or PROPERTIES. But seeing as how they are on different layers, why not just use LAYISO, whoops you are on 2006, I am not sure if that command was around yet or not. LAYISO (for layer isolate) is available in current releases, and a very good command, along with LAYUNISO, which reverses the isolation effect. You could also just FREEZE the layer in which you do not want the multiline style changed, before using QUICK PROPERTIES to easily make the style change on all of those you want changed. Quote
wimal Posted July 3, 2013 Author Posted July 3, 2013 The problem is even I select only one multiline , I can change its colour and layer. But cannot change the multyline style. Quote
Dadgad Posted July 3, 2013 Posted July 3, 2013 The problem is even I select only one multiline , I can change its colour and layer. But cannot change the multyline style. Good point, it is not available for changing via quick properties, nor can you do it with MATCHPROP. I figured that would work, sorry it didn't help you. Quote
MSasu Posted July 3, 2013 Posted July 3, 2013 Up to my knowledge you cannot change the style of a multiline entity, nor adjust the features of a multiline style that is in use. Quote
