Is there a way to auto label every line length of a schematic so that it displays on the cad drawing? Sort of like using the linear dimension tool but for all available lines of a layer or line within a drawing. Any help appreciated.
Thanks.
Maybe take look to FIELD command.
apologies, are you able to elaborate at all? I have looked in here and could not find what to do.
thanks.
Thanks.
There is no one button tool to label them all at one time but if all you need is the text part and not the extension lines and arrowheads then create a dimension style that dispalys only the dimension and use the dimsension commands. There is the Quick Dimension command but the results may not be what is expected.
