Hi guys,
I'm searching a method to select(filter) dimensions with dim roundoff different from 0. Any idea? Ssget or how? Thanks!
Maybe this, if I understood correctly...
[color=#FF0000]([/color][color=BLUE]defun[/color] [color=BLUE]c:ssfiltdimdecimal[/color] [color=#80FF00]([/color] [color=BLUE]/[/color] sss ss i dim d [color=#80FF00])[/color]
 [color=#80FF00]([/color][color=BLUE]setq[/color] sss [color=#00FFFF]([/color][color=BLUE]ssadd[/color][color=#00FFFF])[/color][color=#80FF00])[/color]
 [color=#80FF00]([/color][color=BLUE]setq[/color] ss [color=#00FFFF]([/color][color=BLUE]ssget[/color] [color=BROWN]"_:L"[/color] '[color=#0080FF]([/color][color=#FF00FF]([/color]0 . [color=BROWN]"DIMENSION"[/color][color=#FF00FF])[/color][color=#0080FF])[/color][color=#00FFFF])[/color][color=#80FF00])[/color]
 [color=#80FF00]([/color][color=BLUE]if[/color] ss
   [color=#00FFFF]([/color][color=BLUE]repeat[/color] [color=#0080FF]([/color][color=BLUE]setq[/color] i [color=#FF00FF]([/color][color=BLUE]sslength[/color] ss[color=#FF00FF])[/color][color=#0080FF])[/color]
     [color=#0080FF]([/color][color=BLUE]setq[/color] dim [color=#FF00FF]([/color][color=BLUE]ssname[/color] ss [color=#FF0000]([/color][color=BLUE]setq[/color] i [color=#80FF00]([/color][color=BLUE]1-[/color] i[color=#80FF00])[/color][color=#FF0000])[/color][color=#FF00FF])[/color][color=#0080FF])[/color]
     [color=#0080FF]([/color][color=BLUE]if[/color] [color=#FF00FF]([/color][color=BLUE]not[/color] [color=#FF0000]([/color][color=BLUE]equal[/color] [color=#80FF00]([/color][color=BLUE]fix[/color] [color=#00FFFF]([/color][color=BLUE]setq[/color] d [color=#0080FF]([/color][color=BLUE]cdr[/color] [color=#FF00FF]([/color][color=BLUE]assoc[/color] 42 [color=#FF0000]([/color][color=BLUE]entget[/color] dim[color=#FF0000])[/color][color=#FF00FF])[/color][color=#0080FF])[/color][color=#00FFFF])[/color][color=#80FF00])[/color] d[color=#FF0000])[/color][color=#FF00FF])[/color]
       [color=#FF00FF]([/color][color=BLUE]ssadd[/color] dim sss[color=#FF00FF])[/color]
   [color=#00FFFF]([/color][color=BLUE]prompt[/color] [color=BROWN]"\nEmpty selection set - restart routine"[/color][color=#00FFFF])[/color]
 [color=#80FF00]([/color][color=BLUE]prompt[/color] [color=BROWN]"\nDimensions with decimal places are highlighted"[/color][color=#80FF00])[/color]
 [color=#80FF00]([/color][color=BLUE]sssetfirst[/color] [color=BLUE]nil[/color] sss[color=#80FF00])[/color]
 [color=#80FF00]([/color][color=BLUE]princ[/color][color=#80FF00])[/color]
[color=#FF0000]([/color][color=BLUE]defun[/color] [color=BLUE]c:ssfdd[/color] [color=BLUE]nil[/color] [color=#80FF00]([/color][color=BLUE]c:ssfiltdimdecimal[/color][color=#80FF00])[/color][color=#FF0000])[/color]
[color=#FF0000]([/color][color=BLUE]prompt[/color] [color=BROWN]"\nInvoke with : ssfdd"[/color][color=#FF0000])[/color]
[color=#FF0000]([/color][color=BLUE]princ[/color][color=#FF0000])[/color]
M.R.
I have a dimension 44 mm , then i rounded to 45 (using dim roundoff 5). I want to filter this kind of dimension.
(defun filter_round_distance (ss r / ss1 e o)
 (setq ss1 (ssadd))
   (if
     (and
       (vlax-property-available-p (setq o (vlax-ename->vla-object (setq e (ssname ss (setq i (1- i)))))) 'RoundDistance)
       (equal (vla-get-RoundDistance o) r 1e-
     (setq ss1 (ssadd e ss1))
 ss1
(defun C:TEST ( / s n)
 (if
   (and
     (setq s (ssget '((0 . "*DIM*"))))
     (setq n (getreal "\nRoundoff value: "))
   (sssetfirst nil (filter_round_distance s n))
Try this :
[b]
[color=#FF0000]([/color][color=BLUE]defun[/color] c:ssfiltdimround [color=#80FF00]([/color] [color=BLUE]/[/color] _round sss ss i dim round d [color=#80FF00])[/color]
 [color=#80FF00]([/color][color=BLUE]vl-load-com[/color][color=#80FF00])[/color]
 [color=#80FF00]([/color][color=BLUE]defun[/color] _round [color=#00FFFF]([/color] n d [color=#00FFFF])[/color]
   [color=#00FFFF]([/color][color=BLUE]if[/color] [color=#0080FF]([/color][color=BLUE]<[/color] [color=#FF00FF]([/color][color=BLUE]-[/color] n [color=#FF0000]([/color][color=BLUE]*[/color] [color=#80FF00]([/color][color=BLUE]fix[/color] [color=#00FFFF]([/color][color=BLUE]/[/color] n d[color=#00FFFF])[/color][color=#80FF00])[/color] d[color=#FF0000])[/color][color=#FF00FF])[/color] [color=#FF00FF]([/color][color=BLUE]/[/color] d 2.0[color=#FF00FF])[/color][color=#0080FF])[/color]
     [color=#0080FF]([/color][color=BLUE]*[/color] [color=#FF00FF]([/color][color=BLUE]fix[/color] [color=#FF0000]([/color][color=BLUE]/[/color] n d[color=#FF0000])[/color][color=#FF00FF])[/color] d[color=#0080FF])[/color]
     [color=#0080FF]([/color][color=BLUE]*[/color] [color=#FF00FF]([/color][color=BLUE]+[/color] 1.0 [color=#FF0000]([/color][color=BLUE]fix[/color] [color=#80FF00]([/color][color=BLUE]/[/color] n d[color=#80FF00])[/color][color=#FF0000])[/color][color=#FF00FF])[/color] d[color=#0080FF])[/color]
     [color=#0080FF]([/color][color=BLUE]if[/color] [color=#FF00FF]([/color][color=BLUE]vlax-property-available-p[/color] [color=#FF0000]([/color][color=BLUE]vlax-ename->vla-object[/color] dim[color=#FF0000])[/color] 'rounddistance[color=#FF00FF])[/color]
       [color=#FF00FF]([/color][color=BLUE]progn[/color]
         [color=#FF0000]([/color][color=BLUE]setq[/color] round [color=#80FF00]([/color][color=BLUE]vla-get-rounddistance[/color] [color=#00FFFF]([/color][color=BLUE]vlax-ename->vla-object[/color] dim[color=#00FFFF])[/color][color=#80FF00])[/color][color=#FF0000])[/color]
         [color=#FF0000]([/color][color=BLUE]if[/color] [color=#80FF00]([/color][color=BLUE]not[/color] [color=#00FFFF]([/color][color=BLUE]equal[/color] [color=#0080FF]([/color][color=BLUE]setq[/color] d [color=#FF00FF]([/color][color=BLUE]vla-get-measurement[/color] [color=#FF0000]([/color][color=BLUE]vlax-ename->vla-object[/color] dim[color=#FF0000])[/color][color=#FF00FF])[/color][color=#0080FF])[/color] [color=#0080FF]([/color][color=BLUE]vl-catch-all-apply[/color] '_round [color=#FF00FF]([/color][color=BLUE]list[/color] d round[color=#FF00FF])[/color][color=#0080FF])[/color][color=#00FFFF])[/color][color=#80FF00])[/color]
           [color=#80FF00]([/color][color=BLUE]if[/color] [color=#00FFFF]([/color][color=BLUE]/=[/color] round 0.0[color=#00FFFF])[/color] [color=#00FFFF]([/color][color=BLUE]ssadd[/color] dim sss[color=#00FFFF])[/color][color=#80FF00])[/color]
 [color=#80FF00]([/color][color=BLUE]prompt[/color] [color=BROWN]"\nDimensions witch are rounded and have rounddistance are highlighted"[/color][color=#80FF00])[/color]
[color=#FF0000]([/color][color=BLUE]defun[/color] c:ssfdr [color=BLUE]nil[/color] [color=#80FF00]([/color]c:ssfiltdimround[color=#80FF00])[/color][color=#FF0000])[/color]
[color=#FF0000]([/color][color=BLUE]prompt[/color] [color=BROWN]"\nInvoke with : ssfdr"[/color][color=#FF0000])[/color]
[/b]
M.R.
Edited by marko_ribar
added (vl-catch-all-apply) in case of rounddistance 0.0
