I am using AutoCAD 2013 and, out of nowhere, my keyboard aliases don’t work.
Ex: When I type m for MOVE, I get MADD. When I type co for COPY, I get COLOR.
If I turn off ‘Auto Append’, and try it, I get ‘UNKNOWN COMMAND’.
I’m at a loss as to what to do.
(I checked to see if I lost the acad.pgp file, but it’s still there.)
Looking for suggestions on how to get them back.
Thank you.
  • Replies 22
  • alanjt
    9
  • Laurie E
    8
  • nestly
    5
  • Tyke
    1
Popular Days
Autocad could be finding a bad acad.pgp file.
Type: (findfile "acad.pgp") in the command line and see what comes up. It should be something like c:\users\\appdata\autodesk\//support
Autocad will always load only the first one it finds. Same as the acad.lsp and the acaddoc.lsp
Assuming the pgp is where it's supposed to be, try restarting AutoCAD or type REINIT to reload it.
Thank you both for replying, but nothing is working. When I type (findfile "acad.pgp"), it says 'nil'.
I also tried restarting AC, and typing REINIT and it still isn't working.
Any other ideas?
That's bothersome.
Type START then type acad.pgp and see if it opens the file. If not, it's not finding your acad.pgp file. It's either been deleted, or the path is no longer in the support paths.
Should I tell you that I am running Windows 7?
I find the pgp file in the following path:
c:Program Files/Autodesk/AutoCAD 2013/UserDataCache/en-us/Support
Perhaps the AutoCAD profile is changed or became corrupt. There may or may not be an alternate profile you can try (Tools > Options > Profiles) to see if the command alias's work with a different profile.
Command: (findfile "acad.pgp")
"C:\\Users\\<username>\\appdata\\roaming\\autodesk\\c3d 2011\\enu\\support\\acad.pgp"
Type START on the command line? I tried, and a suggestion pops up saying STARTUP. When I just try to type START, I get UNKNOWN COMMAND.
(I should add that the geniuses at our main office accessed my computer remotely to attempt to fix an unrelated problem and now I have lost settings in other programs as well, but none are as bothersome as my AutoCAD issues.)
I accessed another profile and they still don't work.
Time to run a repair on your installation.
Is it a dumb idea to delete the pgp file from my computer (maybe it IS corrupted?), then copy the file from another computer to a shared drive, then copy that back to my computer?
Can you tell me how to run a repair? I've never done that.
Worth a try. I was actually about to post the pgp from my installation and see if it would work. Check your support paths in options and make sure it still has some available.
control panel>programs>programs and features>autocad>right-click + uninstall/change>repair
IT may have limited your privileges. You should check with them first, just so you don't get in trouble for editing the software. If they screwed it up, let them fix it.
I believe "Start" is referring to the Windows Start menu, but I think you already answered the question. Whatever your IT guys did removed the acad.pgp file that your AutoCAD profile accesses. You should have at least 2 acad.pgp files on your computer, one in Program Files > Autodesk.... which you apparently do have, and the one directly accessed by Autocad in Users\\\\appdata.... which appears to be missing. I'm thinking that Windows Restore and/or AutoCAD repair/reinstall may be necessary.
No, start was referring to typing it in the command line. You can access the pgp file from one of the pulldown menus, but it's been years since I've done that and can't remember which one it is.
Interesting, about "START"... The PGP file is accessible from Express > Tools > Command Alias Editor
Yeah, ET has it's own editor for acad.pgp
I believe you are correct that I am missing the pgp file in the Users path. Is that something I can copy from one computer to another or should I try a repair. (I hesitate to do a System Restore because I'm fairly certain that is one of the things our MIS guys did to mess up my system and I have no idea what date they used.)
