i need help. i inadvertently overwrote a file i just edited and saved with a file that is previously unedited. all that remains of the new file is .bak copy. however i cannot open the .bak file. is there someone out there who could bail me out? thank you very much.
Using Windows Right Click, Rename function, change the .bak extension to .dwg, then open it.
The only way this is going to help you is if you overwrote the drawing file with a file name different than the .bak file. The .bak file is a copy of the last Save command executed. For instance, if you wanted to keep drawing1.dwg, but overwrote it with drawing2.dwg by doing a save (drawing2.dwg) as (drawing1.dwg), then the .bak file for drawing1.dwg is going to look just like drawing2.dwg.
Is there a copy of the original drawing file saved on another media like a CD, DVD, or flash drive? How about on a network drive assuming this is work related?
