What's the difference between common lisp and autolisp?? i have this code common lisp for reverse text:
"hello world" ----> "dlrow olleh"
the code is:
(defun C:reverse()
   (vl-list->string (reverse (vl-string->list str))
(SETQ MMT (getstring())
(REVERSE(MMT))
but dont work:(
Edited by hosyn
The first thing that you have used the function reverse as a name of function which is can not perform as sub-function since that it is a built-in function , secondly your function is correct but with a missing paren to be completed .
try .
(defun rev (str)
   (vl-list->string (reverse (vl-string->list str)))
How can that code work for reverse :
Why did you modify your first post after my reply ? :glare:
Huh ؟؟؟ :huh:
dear tharwat
I try the fierst one and dont have good resault--i thoght that the first code in begun have problem:cry:.
i correct the prantess as you mentioned but unfortunately dont get result.
Hosyn, to fix your code:
(defun C:ReverseString( / )
(if (SETQ MMT (getstring "\nInput string to be reversed: "))
 (print (vl-list->string (reverse (vl-string->list MMT))))
Alternatively, using only Vanilla AutoLISP:
(defun reversestring ( str / lst )
   (repeat (strlen str)
       (setq lst (cons (substr str 1 1) lst)
             str (substr str 2)
   (apply 'strcat lst)
_$ (reversestring "Hello World!")
"!dlroW olleH"
Stange that the code in VisualLisp has more characters (therefore longer) than...
...the vanilla AutoLisp code.
         str (substr str 2)
   (apply 'strcat lst)
LibertyOne, the VLISP code you used in comparison contains in fact extra statements to allow for testing. Instead should check against this:
(defun ReverseString( str / )
How about using system variable Mirrtext set to 1. :)
Or,
(defun c:revtxt ( / i s )
   (if (setq s (ssget "_:L" '((0 . "TEXT") (-4 . "<NOT") (-4 . "&=") (71 . 2) (-4 . "NOT>"))))
       (repeat (setq i (sslength s))
           (vla-put-backward (vlax-ename->vla-object (ssname s (setq i (1- i)))) :vlax-true)
(vl-load-com) (princ)
Dong95, I believe that the OP was looking to programatically reverse a string stored into a variable (that it, invert the order of its characters), not to show in mirror a text entity in editor; example:
"MIRRTEXT" --> "TXETRRIM"
  • 6 months later...
Can you all make a lisp with select all txt mtxt and reverse value on that in a drawing?
Cuasuavdd, a routine to batch reverse all TEXT type labels in the drawing using one of the above proposed solutions will be quite easy. However, for MTEXT will be a quite laborious task since for those the formatting is retained as control strings along text value, so will need to be skipped at reverse.
Also, welcome to the Forum!
