alijahed Posted July 8, 2013 Posted July 8, 2013 Hi All, I want to drop an exe file on the CAD user's desktop so when the user executes that file it automatically setup his/her AutoCAD in a way that I want. I tried to find my answer on the web but was unsuccessful. I found "Inno Setup and AcadInstall" but couldn't find any further details on these like a tutorial and downloading the software from a safe place. I've also noticed those threads were old like 2005. Can somebody please help me with this? Cheers Ali Quote
ReMark Posted July 8, 2013 Posted July 8, 2013 Wouldn't the customization be better handled via an enterprise.cuix that is read only and is unable to be modified by users? Quote
alijahed Posted July 8, 2013 Author Posted July 8, 2013 Hey dude, How r u? Mate, I want to do the followings: 1. Create another AutoCAD shortcut on desktop. So enables the user to have his own interface and the one that I developed. 2. On the Tools>Options>Files change the following addresses to my server or URL addresses: Customization File Main Customization File C:\Users\cplus\appdata\roaming\autodesk\autocad 2014\r19.1\enu\support\acad Enterprise Customization File . Custom Icon Location C:\Users\cplus\appdata\roaming\autodesk\autocad 2014\r19.1\enu\support\icons Printer Support File Path Print Spooler File Location C:\Users\cplus\appdata\local\temp\ Printer Configuration Search Path C:\Users\cplus\appdata\roaming\autodesk\autocad 2014\r19.1\enu\plotters Printer Description File Search Path C:\Users\cplus\appdata\roaming\autodesk\autocad 2014\r19.1\enu\plotters\pmp files Plot Style Table Search Path C:\Users\cplus\appdata\roaming\autodesk\autocad 2014\r19.1\enu\plotters\plot styles Template Setting Drawing Template File Location C:\Users\cplus\appdata\local\autodesk\autocad 2014\r19.1\enu\template Tool Palettes File Locations C:\Users\cplus\AppData\Roaming\Autodesk\AutoCAD 2014\R19.1\enu\support\ToolPalette Action Record Setting Actions Recording File Location C:\Users\cplus\appdata\roaming\autodesk\autocad 2014\r19.1\enu\support\actions 3. Copy Lisp files on their hard drive from a url or server in a particular location 4. Add Lisp routines to the start up 5. Open my template 6. Add my toolbars At the moment I have to jump on their computers to do all these changes which I want to avoid. Cheers Ali Quote
Pablo Ferral Posted July 8, 2013 Posted July 8, 2013 Try using Lisp instead. Here's a couple of examples... http://forums.augi.com/showthread.php?56760-Routine-to-set-search-paths-file-names-and-file-locations http://www.augi.com/library/managing-customization-files Quote
BIGAL Posted July 12, 2013 Posted July 12, 2013 Heres a lisp for setting all the paths, but a better way is to create a ARG from Profiles. Quick answer copy ARG to new pc, make new icon pointing to this ARG, start default AutoCAD icon load ARG then close. Copy you custom menu to location in your path settings for "Main customisation menu", start your new icon Should work ! 12 pc's done this way ; resets the paths usefull for update versions of Autocad ; by BGAL 2011 ; This sets a reference to the install path of your product ; the gets are their for info maybe other use ; use this to find other settings ;(vlax-dump-object (vla-get-files (vla-get-preferences (vlax-get-Acad-object))) T) (vl-load-com) ; make temp directory ;(vl-mkdir "c:\\AcadTEMP") (setq *files* (vla-get-files (vla-get-preferences (vlax-get-Acad-object)))) ; savepath ;(vla-get-AutoSavepath *files*) (vla-put-AutoSavepath *files* "C:\\AcadTemp") ; custom icons ;(vla-get-CustomIconPath *files*)) (vla-put-CustomIconPath *files* "P:\\Autodesk\\ICONS") ; custom menu ;(vla-get-Menufile *files*)) ;(vla-put-Menufile *files* "C:\\Users\\2013BIGAL") ; printers config ;(vla-get-PrinterConfigPath *files*) (vla-put-PrinterConfigPath *files* "P:\\AutoDESK\\Plotting\\Plot Styles 2011") ; printers style sheet ;(vla-get-PrinterStyleSheetPath *files*) (vla-put-PrinterStyleSheetPath *files* "P:\\AutoDESK\\Plotting\\Plot Styles") ; printer drv's ;(vla-get-PrinterDescPath *files*) (vla-put-PrinterDescPath *files* "P:\\AutoDESK\\Plotting\\Drv") ; print spooler ;(vla-get-PrintSpoolerPath *files*) (vla-put-PrintSpoolerPath *files* "C:\\AcadTemp\\") ; template path ;(vla-get-TemplateDwgPath *files*) (vla-put-TemplateDwgPath *files* "P:\\Autodesk\\c3d Templates") ; template location ;(vla-get-QnewTemplateFile *files*) (vla-put-QnewTemplateFile *files* "P:\\Autodesk\\c3d Templates\\BIGAL.dwt") ;make new support paths exist + new (setq paths (vla-get-SupportPath *files*)) (setq BIGALpaths "P:\\autodesk\\supportfiles; P:\\autodesk\\lisp; P:\\autodesk\\fonts; P:\\autodesk\\hfs fonts;" ) (setq newpath (strcat BIGALpaths paths)) (vla-put-SupportPath *files* newpath) ; Tempdirectory ;(vla-get-TempFilePath *files*)) (vla-put-TempFilePath *files* "C:\\AcadTemp\\") (vla-put-PlotLogFilePath *files* "C:\\AcadTemp\\") (vla-put-LogFilePath *files* "C:\\AcadTemp\\") ; xref temp path ;(vla-get-TempXrefPath *files*)) (vla-put-TempXrefPath *files* "C:\\AcadTemp\\") ; end use of *files* (vlax-release-object *files*) ; exit quitely (princ "All Done") Quote
feargt Posted July 12, 2013 Posted July 12, 2013 Heres a lisp for setting all the paths, but a better way is to create a ARG from Profiles. Quick answer copy ARG to new pc, make new icon pointing to this ARG, start default AutoCAD icon load ARG then close. Copy you custom menu to location in your path settings for "Main customisation menu", start your new icon quicker again, is to put the arg file on the network and create a desktop icon with a switch that points to it. i.e. /p "\\.......\........\myprofile.arg" Quote
alijahed Posted July 15, 2013 Author Posted July 15, 2013 Thanks for your reply guys. But I am still seriously curious on how to make the exe file. Can anybody help me with this? Quote
ReMark Posted October 25, 2013 Posted October 25, 2013 Autohotkey or AutoIT If this is supposed to be an answer perhaps a little more detail would be helpful. A brief explanation and maybe a link to the appropriate website? Quote
NewVillage Posted October 25, 2013 Posted October 25, 2013 Your original reply: Is this supposed to be an answer, a question, or the ramblings of a confused mind? A little more detail would be helpful. For AutoIT, make a script. Use its Send command to simulate keystrokes to the active window. When all is working, make an .exe of the script. Quote
