pqphillips Posted July 9, 2013 Posted July 9, 2013 Okay guys... I'm working on a system where I have power coming out of a device and hitting a busbar. I have the busbar as a separate layer and have added it as a wire type to the system. The issue I have is having it come out the device as a regular wire and attach to the busbar. When I do this, ACADE switches the wire to be on the busbar layer. Anyone know how to alleviate this? Quote
pqphillips Posted July 9, 2013 Author Posted July 9, 2013 Nope. Basic wire connection with a connection dot. Not polylines. Quote
ReMark Posted July 9, 2013 Posted July 9, 2013 Did you try using the Change/Convert Wire Type command? Quote
pqphillips Posted July 9, 2013 Author Posted July 9, 2013 If I do that, it changes the wire and the busbar into the selected wire type. Quote
dbroada Posted July 9, 2013 Posted July 9, 2013 can the busbar be defined as a terminal rather than a wire? Quote
ReMark Posted July 9, 2013 Posted July 9, 2013 I'm guessing that Change All Wire(s) in the Network is currently enabled right? What if you were to disable it? Quote
pqphillips Posted July 9, 2013 Author Posted July 9, 2013 can the busbar be defined as a terminal rather than a wire? I'd rather not do that... I'm guessing that Change All Wire(s) in the Network is currently enabled right? What if you were to disable it? That did it! I had to manually select all the segments and crossover loops, but it worked! Thanks, man! Quote
ReMark Posted July 9, 2013 Posted July 9, 2013 Another correct albeit wild guess! LoL You're entirely welcomed. Quote
