Ok i've modeled this rubik's cube and It wont spin even though (i'm pretty sure) i've constrained it properly
Been stuck on it for a while so would appreciate it if someone would look at it and see if I did mess up something
I can't post websites so I jsut attached the link to the download in a .txt it's 1.07mb or somethign so i couldn't upload it here
the file in question is Cube_3.iam
thanks in advance, K4D
website.txt
Won't let me download it ?
Got it! just having a look.
Your model is great well done, I really think (having a quick look) the contraints are the problem, to solve it may be a bigger problem (no pun intended) I will have aplay with it and see what I can do, I would like to hear from JD, Aardvark and Swift to see what they think to making this work?
Thanks, used my trusty ruler and took apart my own cube =)
tried to get it as realistic as possible, but yeah the constraints are a nightmare, have had to redo them 3 times so far hence Cube_3 lol
I just don't want to have to keep redoing them without someone else giving me advice on it as i seem to always mess it up
I will need to take it apart the redo the constraints with angle constraints, then drive the angle constraint to 90 degree a time, this is the only way I think it will work, it's quite complex but would be wicked to see it working.
I don't have inventor on this computer but I was fairly sure I had my sketches constrained...
and reading through that tutorial doesn't look like anything too new to me so not sure where you want me to start in there, it's a nice tutorial though!
