In this code
(setq valor_area 0.0000)
(setq sel (ssget "_x" (list '(0 . "HATCH")(cons 8 layer))))
(if (/= sel nil)
  (setq i 0)
  (repeat (sslength sel)
      (setq entbh (ssname sel i))
      (if (/= entbh nil)
           (setq lentbh (entget entbh))
           (setq layerbh (cdr(assoc 8 lentbh)))
           (setq valor_area(+ valor_area (vla-get-area (vlax-ename->vla-object entbh))))
The error is in this line
I received the Automation error, how to handling this problem ?
I need that when the error occurs and the system to zoom in on the problem with hatch.
Thanks
Nothing is wrong with the code , unless you have this is a part of another routine ;)
Tharwat ,
I could help to create a handling for this part of the code
vla-get-area (vlax-ename-> vla-object entbh)
If a problem arises you need to zoom in on the hatch and stop the process.
Try it this way ..
(setq valor_area 0.0)
(if (setq sel (ssget "_x" (list '(0 . "HATCH") (cons 8 layer))))
 (repeat (setq i (sslength sel))
   (setq entbh (ssname sel (setq i (1- i))))
   (setq valor_area
          (+ valor_area
The ActiveX area property will not be available for Hatch objects with a self-intersecting boundary - this is likely causing the error you are experiencing.
Here is one way to bypass the issue:
(defun c:harea ( / a i j r s )
   (setq r 0.0 j 0)
   (if (setq s (ssget "_X" '((0 . "HATCH"))))
       (repeat (setq i (sslength s))
           (if
               (vl-catch-all-error-p
                   (setq a
                       (vl-catch-all-apply 'vla-get-area
                           (list (vlax-ename->vla-object (ssname s (setq i (1- i)))))
               (setq j (1+ j))
               (setq r (+ r a))
   (if (< 0.0 r)
       (princ (strcat "\nTotal Area: " (rtos r 2)))
   (if (< 0 j)
       (princ (strcat "\n" (itoa j) " had a self-intersecting boundary."))
I need to do some tests and I'll be back.
Thanks to all!
