abishop Posted July 16, 2013 Posted July 16, 2013 OK, I made an ASSY file of 3 parts in Inventor. Each part was an IGS file. They are all NON Translucent files. I save this .iam file. Then I create a .igs file. I open this file up and it is all TRANSLUCENT! I open the idividual files from the .igs file and they are trans. I click the trans OFF and save. It changes it in my ASSY .igs file to solid. I save the assy .igs file. Close them all down and open the .igs file and they are all trans again..............what the crap! Quote
JD Mather Posted July 16, 2013 Posted July 16, 2013 This doesn't sound like you understand difference between solid bodies and surface bodies. (changing translucency has nothing to do with changing to solid body) It also sounds like you aren't changing the Options on export/import. http://home.pct.edu/~jmather/AU2008/ML205-1P%20Mather.pdf zip and attach your files here. Quote
Lazer Posted July 24, 2013 Posted July 24, 2013 Not quite sure what you are asking? The translucent is a visual aid, you can change it in the history tree, RMC the part and untick translucent. Quote
